Search for the lowest point
orhan.alihanov
orhan.alihanov
Hello! I want to create the drawing , add a view of 3D , create a sketch, add a line through the lowest point of the projection. I've already written the bulk of the code, but I can't seem to get the projection of the geometry onto the sketch to find the lowest point...
Dim invApp As Inventor.Application
invApp = ThisApplication
Dim partDoc As PartDocument = ThisDoc.Document
Dim tg As TransientGeometry = ThisApplication.TransientGeometry
' Определение пути к шаблону
Dim templatePath As String
templatePath = ".\Templates\Standard.dwg"
Dim newDrawingDoc As DrawingDocument
newDrawingDoc = invApp.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, templatePath, True)
newDrawingDoc.Activate()
Dim oSheet As Sheet = newDrawingDoc.ActiveSheet
Dim frontView As DrawingView
frontView = oSheet.DrawingViews.AddBaseView(partDoc, tg.CreatePoint2d(x,y), 1/50, ViewOrientationTypeEnum.kBackViewOrientation, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle)
Dim sketch As Sketch = frontView.Sketches.Add()
sketch.Edit
'all geometry is projected here,
' the lowest point is determined,
'startPoint and endPoint are defined
Dim line As SketchLine = sketch.SketchLines.AddByTwoPoints(startPoint, endPoint)
line.LineWeight = 0.01
sketch.ExitEdit()
JelteDeJong
Most of the code below I took from this blog post "Automatically generate overall dimensions". (Here I use the first drawing view on the active sheet. That is different from your code.)  It has a function to get all intent points of a view. That list includes the bottom point. With a sorting function, you can get the bottom intent and use it in your sketch.
Public Class ThisRule
    Private _doc As DrawingDocument
    Private _sheet As Sheet
    Private _view As DrawingView
    Private _intents As List(Of GeometryIntent) = New List(Of GeometryIntent)()
    Sub Main()
        _doc = ThisDoc.Document
        _sheet = _doc.ActiveSheet
        _view = _sheet.DrawingViews.Item(1)
        CreateIntentList()
        CreateLowestPointLine()
    End Sub
    Private Sub CreateLowestPointLine()
        Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.Y)
        Dim intentBottom = orderedIntents.Last
        Dim sketch As DrawingSketch = _view.Sketches.Add()
        sketch.Edit()
        Dim bottomSketchPoint As Point2d = sketch.SheetToSketchSpace(intentBottom.PointOnSheet)
        Dim sketchPointEnd As Point2d = ThisApplication.TransientGeometry.
            CreatePoint2d(bottomSketchPoint.X - 5, bottomSketchPoint.Y)
        sketch.SketchLines.AddByTwoPoints(bottomSketchPoint, sketchPointEnd)
        ' If you need the SketchEntity to constraint your line then you can get it like this:
        ' Dim entity As SketchEntity = sketch.AddByProjectingEntity(intentBottom.Geometry)
        sketch.ExitEdit()
    End Sub
    Private Sub CreateIntentList()
        For Each oDrawingCurve As DrawingCurve In _view.DrawingCurves
            Select Case oDrawingCurve.ProjectedCurveType
                Case _
                        Curve2dTypeEnum.kCircleCurve2d,
                        Curve2dTypeEnum.kCircularArcCurve2d,
                        Curve2dTypeEnum.kEllipseFullCurve2d,
                        Curve2dTypeEnum.kEllipticalArcCurve2d
                    addIntent(oDrawingCurve, PointIntentEnum.kCircularTopPointIntent, True)
                    addIntent(oDrawingCurve, PointIntentEnum.kCircularBottomPointIntent, True)
                    addIntent(oDrawingCurve, PointIntentEnum.kCircularLeftPointIntent, True)
                    addIntent(oDrawingCurve, PointIntentEnum.kCircularRightPointIntent, True)
                    addIntent(oDrawingCurve, PointIntentEnum.kEndPointIntent, False)
                    addIntent(oDrawingCurve, PointIntentEnum.kStartPointIntent, False)
                Case _
                        Curve2dTypeEnum.kLineCurve2d,
                        Curve2dTypeEnum.kLineSegmentCurve2d
                Case _
                    Curve2dTypeEnum.kPolylineCurve2d,
                    Curve2dTypeEnum.kBSplineCurve2d,
                    Curve2dTypeEnum.kUnknownCurve2d
                    ' Unhandled curves types
                Case Else
            End Select
        Next
    End Sub
    Private Sub addIntent(Geometry As DrawingCurve, IntentPlace As Object, onLineCheck As Boolean)
        Dim intent As GeometryIntent = _sheet.CreateGeometryIntent(Geometry, IntentPlace)
        If intent.PointOnSheet Is Nothing Then Return
        If onLineCheck Then
            If (IntentIsOnCurve(intent)) Then
                _intents.Add(intent)
            End If
        Else
        End If
    End Sub
    Private Function IntentIsOnCurve(intent As GeometryIntent) As Boolean
        Dim Geometry As DrawingCurve = intent.Geometry
        Dim sp = intent.PointOnSheet
        Dim pts(1) As Double
        Dim gp() As Double = {}
        Dim md() As Double = {}
        Dim pm() As Double = {}
        Dim st() As SolutionNatureEnum = {}
        pts(0) = sp.X
        pts(1) = sp.Y
        Try
            Geometry.Evaluator2D.GetParamAtPoint(pts, gp, md, pm, st)
        Catch ex As Exception
            Return False
        End Try
        Return True
    End Function
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
