Saving a corner stamp to Word
DeptaM
DeptaM
Hello colleagues,
I need to export a corner stamp ideally into Word. I need to print it on a self-adhesive label. Has anyone of you solved something similar?
Thank you
Michael.Navara
You can easily convert TitleBlock to SketchedSymbol.
Now you can print labels directly from Inventor. This sketched symbols can display properties from different models.
VBA code sample how to copy title block "DIN" to sketched symbol "TitleBlockCopy"
Sub CopyTitleBlockToSketchedSymbol()
    Dim drw As DrawingDocument
    Set drw = ThisApplication.ActiveDocument
    Dim tbDef As TitleBlockDefinition
    Set tbDef = drw.TitleBlockDefinitions("DIN")
    Dim ssDef As SketchedSymbolDefinition
    Set ssDef = drw.SketchedSymbolDefinitions("TitleBlockCopy")
    Call tbDef.Sketch.CopyContentsTo(ssDef.Sketch)
End Sub
navya_gelli
Hello @DeptaM
Did Michael.Navara's response answer your question and resolve the issue? If so, please consider marking it as the solution to help other community members with similar questions. If you're still looking for a solution, please share an update here so the community can continue to assist.
Navya | Community Manager
