saveas bmp
saveas bmp
arrakisman
saveas bmp
arrakisman
Does any one know how to control the resolution of a bmp when exporting an sheet. I found how to do it with a view but I need the entire sheet.
The reason this method is on a view is because you can have multiple views open at a time and this is a way to specify which view. You've probably also found that when you save a bmp it captures everything in the view. I've written a small routine that resizes the view and zooms in on the sheet so that the view only displays the sheet. It then writes out the bmp file. I have an argument that specifies the desired resolution of the output in pixels per inch. Hopefully this is what you need. ' Saves the active sheet as a bmp. ' Resolution - Specifies the output resolution of the bitmap in pixels per inch. ' Filename - Specifies the output filename. It should have a .bmp extension. Public Sub SaveDrawingAsBMP(Resolution As Long, Filename As String) ' Get the active view. Dim oView As View Set oView = ThisApplication.ActiveView ' Determine if a drawing is active. If Not oView.Document.DocumentType = kDrawingDocumentObject Then MsgBox "A drawing must be active when running this macro." Exit Sub End If ' Get the drawing document and the active sheet. Dim oDoc As DrawingDocument Set oDoc = oView.Document Dim oSheet As Sheet Set oSheet = oDoc.ActiveSheet ' Change the size of the window so it has the same aspect ratio ' as the sheet. It changes the view such that it becomes smaller. oView.WindowState = kNormalWindow Dim dSheetAspectRatio As Double dSheetAspectRatio = oSheet.Width / oSheet.height Dim dViewAspectRatio As Double dViewAspectRatio = oView.Width / oView.height If dSheetAspectRatio > dViewAspectRatio Then oView.height = oView.Width / dSheetAspectRatio Else oView.Width = oView.height / dSheetAspectRatio End If ' Get the camera and use it to zoom in so only the sheet is seen. Dim oCamera As Camera Set oCamera = oView.Camera oCamera.Target = ThisApplication.TransientGeometry.CreatePoint(oSheet.Width / 2, oSheet.height / 2, 0) oCamera.Eye = ThisApplication.TransientGeometry.CreatePoint(oCamera.Target.X, oCamera.Target.Y, 1) Call oCamera.SetExtents(oSheet.Width, oSheet.height) oCamera.ApplyWithoutTransition ' Determine the number of pixels wide the output needs to be ' to result in the desired resolution. Dim lWidth As Long lWidth = (oSheet.Width / 2.54) * Resolution ' Save the bitmap. Call oView.SaveAsBitmap(Filename, lWidth, 0) End Sub -- Brian Ekins Autodesk Consulting Services Discussion Q&A: http://www.autodesk.com/discussion "arrakisman" wrote in message news:31064762.1100111881980.JavaMail.jive@jiveforum1.autodesk.com... > Does any one know how to control the resolution of a bmp when exporting an sheet. I found how to do it with a view but I need the entire sheet.
arrakisman
Thank a whole lot Brian.. I will try it out.
