Save PDF using iLogic and name after revision number?
GustavStigsohn
Message 1 of 48
GustavStigsohn
Hello!
My question: We want to use iLogic to save a PDF-file of the DWG-drawing every time we hit "save". We now use the following iLogic code:
Spoiler
oPath = ThisDoc.Path PN = iProperties.Value("Project", "Part Number") PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oDocument = ThisApplication.ActiveDocument oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium  If PDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 1 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 2 'oOptions.Value("Custom_End_Sheet") = 4 End If  'Set the destination file name oDataMedium.FileName = oPath & "\" & PN & ".pdf"  'Publish document PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions,oDataMedium)  'Confirmation message MessageBox.Show("PDF SAVED TO: " & oDataMedium.FileName ,"PDF Saved", MessageBoxButtons.OK)
Question 1: Is it possible to save the PDF in a new folder that lies "one step up". For example: My DWG-file is placed in c:/drawings/thing4/DWG, I want the PDF to end up in c:/drawings/thing4/PDF. If I am in folder "c:/drawings/thing2/DWG" I want the PDF to end up in "c:/drawings/thing2/PDF" etc. Possible?
Question 2: My DWG files is named "thing4.dwg" and it is the 2nd revision. I want the PDF-file to be named
"thing4 Ed2.pdf". Possible?
Any help would be very appreciated!
/Gustav
Replies (47)
Message 21 of 48
james.nahani
This is the code:
'------- start of iLogic code -------------------
' Get the DWG translator Add-In.
Dim DWGAddIn As TranslatorAddIn
DWGAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
'Set a reference to the active document
Dim oDocument As Document
Dim oContext As TranslationContext
' Create a NameValueMap object
Dim oOptions As NameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
' Check whether the translator has 'SaveCopyAs' options
If DWGAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
    ' DWG version.
    ' 23 = ACAD 2000
    ' 25 = ACAD 2004
    ' 27 = ACAD 2007
    ' 29 = ACAD 2010
    oOptions.Value("DwgVersion") = 25
Dim strIniFile As String
strIniFile = "C:\temp\DWGout.ini"
' Create the name-value that specifies the ini file to use.
oOptions.Value("Export_Acad_IniFile") = strIniFile
End If
'get path and file name
path_and_name = ThisDoc.PathAndFileName(False) ' without extension
'Set the DWG target file name
oDataMedium.FileName = path_and_name & ".DWG"
DWGAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'------- end of iLogic code -------------------
Message 22 of 48
Not sure. Your code works here. I copied and paste your code into a new rule in an existing IDW and it generated the exported DWG just fine. My suggestion to you then is try debugging this code by placing in messageboxes at different locations in the code. Then see which messagebox does not display. This way you can narrow down the search to the line of code that's causing this error.
Message 23 of 48
If you copied the code I posted it might be the spaces before and after Rev, " Rev ".
Message 24 of 48
james.nahani
I am putting the code to a inventor.dwg drawing not .idw, can that be the problem?
Off topic, i dont really get it why i should use idw when i can use dwg.
Message 25 of 48
Now that you say that, it actually is and is not the problem. 🙂 The code is written to use the file name of the current file as the exported DWG. Well since the current file is already a DWG, it's is going to try and overwrite itself with the exported DWG. that's why there's that error. To correct this, use a different name for the exported dwg. Maybe use this line of code instead when defining the filename of the exported dwg.
oDataMedium.FileName = path_and_name & "-Exported.DWG"
Hope that helps.
Dan
Message 26 of 48
jostroopers
Curtis, it is great how you use ilogic and i used your code  to save each sheet as a single PDF into the same folder that the DWG/IDW resides in.
But i want to create a folder calded "PDF" in the same folder where the DWG resides in and put in de pfd's.
I hope you can help me out.
Thanks, Jos
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
Message 27 of 48
Which one of the codes he has posted? Please post your code 🙂
Message 28 of 48
jostroopers
I used this code.
'------start of iLogic------- oPath = ThisDoc.Path oFileName = ThisDoc.FileName(False) 'without extension oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _ ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oDocument = ThisApplication.ActiveDocument oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium 'Define the drawing Dim oDrawing As DrawingDocument oDrawing = ThisDoc.Document Dim oSheet As Sheet Dim lPos As Long Dim rPos As Long Dim sLen As Long Dim sSheetName As String Dim iSheetNumber As Integer 'step through each drawing sheet For Each oSheet In oDrawing.Sheets 'find the seperator in the sheet name:number lPos = InStr(oSheet.Name, ":") 'find the number of characters in the sheet name sLen = Len(oSheet.Name) 'find the sheet name sSheetName = Left(oSheet.Name, lPos -1) 'find the sheet number sSheetNumber = Right(oSheet.Name, sLen -lPos) 'set PDF Options If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 1 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintSheetRange oOptions.Value("Custom_Begin_Sheet") = sSheetNumber oOptions.Value("Custom_End_Sheet") = sSheetNumber End If 'Set the PDF target file name oDataMedium.FileName = oPath & "\" & oFileName & "_" & sSheetName & sSheetNumber & ".pdf" 'Publish document oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) Next '------end of iLogic-------
Mvg Jos
Message 29 of 48
jostroopers
I also wanted to use this:
'get PDF target folder path
oFolder = Left(oPath, InStrRev(oPath, "\")) & "PDF"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
End If
Then the folder 'PDF' is made but the pdf files don't get in that folder.
Mvg Jos
Message 30 of 48
Try to this for the first line
oPath = ThisDoc.Path & "\PDF"
Message 31 of 48
jostroopers
I have now the following code.
But i have a problem.
It now makes the new folder and it puts in the pdf with the good name.
But every pdf is saved with the first sheet.
So the second pdf has the good name but the wrong sheet saved.
 'query user
question = MessageBox.Show("Do you want to create a PDF?", "iLogic Question",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
'set condition based on answer
If question = vbNo Then
'exit the rule
Return
Else If question = vbYes Then
End If
'Define the drawing
Dim oSheet As Sheet
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
'set PDF Options
End If
End If
oDataMedium.FileName = oPath & "\" & oFileName & "_" & sSheetName & ".pdf"
'Publish document
Next
Mvg Jos
Message 32 of 48
jostroopers
I also have this code where i want to save all sheets in one pdf and placed in the PDF folder in the same folder where the DWG is.
I get the sheets saved in one pdf and i get the PDF folder but the pdf want get into the PDF folder.
It gets in the folder where the DWG is and where the PDF folder is made.
 'query user
'exit the rule
Return
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
End If
End If
End If
oDataMedium.FileName = oFilename & ".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions,oDataMedium)
Mvg Jos
Message 33 of 48
Well, without trying this code it looks like the target pdf folder is written two places.
Make a messagebox showing the target path.
MessageBox.Show(oFolder, "iLogic")
Is the path correct? if not try to remove one of the PDF in oFolder or oPath, does not matter which one.
Message 34 of 48
Curtis_Waguespack
Hi   jostroopers,
If you look at the example at this link:
http://inventortrenches.blogspot.com/2011/07/ilogic-to-save-pdf-files-to-new.html
You will see that the oDataMedium line include the oFolder variable:
oDataMedium.FileName = oFolder & "\" & oFileName & " " & sSheetName & " " & sSheetNumber  & ".pdf"
In your examples the oFolder variable is not included:
I hope this helps.
Curtis
Message 35 of 48
jostroopers
I changed the code but it stil dusn't work.
It now saves the idw into a pdf in the PDF folder and the names of the pdf are good.
But each pdf is saved with the first sheet of the idw.
I used the Example Drawing where in made 3 sheets.
I now have this code:
 'query user
'exit the rule
Return
End If
'Define the drawing
Dim oSheet As Sheet
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
'set PDF Options
End If
End If
'Publish document
Next
Mvg Jos
Message 36 of 48
Curtis_Waguespack
Hi jostroopers,
Okay, I found the mistake in this code, it had to do with the use of
sSheetNumber rather than iSheetNumber
The code below should work.
I hope this helps.
Curtis
 'query user
'exit the rule
Return
End If
'Define the drawing
Dim oSheet As Sheet
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
iSheetNumber = Right(oSheet.Name, sLen -lPos)
'set PDF Options
oOptions.Value("Custom_Begin_Sheet") = iSheetNumber
oOptions.Value("Custom_End_Sheet") = iSheetNumber
End If
End If
oDataMedium.FileName = oFolder & "\" & oFileName & " " & sSheetName & " " & iSheetNumber  & ".pdf"
'Publish document
Next
Message 37 of 48
jostroopers
Curtis, thanks very much.
The code is working just great.
Btw did you change your code on your blog because i had the same problem but i tried your code again and now that code is working?
But anyway, Thanks.
Mvg Jos
Message 38 of 48
Hi Curtis, what would be the right code fro export drawing to singelsheets with revision number?
Message 39 of 48
Hi, I'm Max from Italy!
Can anyone reply to my problem?
I've tried to paste the following code
SyntaxEditor Code Snippet
'Define the drawing
Dim oSheet As Sheet
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
'set PDF Options
End If
'Publish document
Next
but when I start the rule there are 2 differrent sheet with the pdf printed of the first sheet; insted I'd like to obtain 2 pdf with two different sheet!
Kind regard
Message 40 of 48
FProcp
This is great, I love Heart having pdf's saved automatically so other people in the office can view drawings!
I would like to add code to turn off a layer before creating the pdf and then turn it back on again.
There's a layer I do not want on the pdf.
That information must not be on the pdf's so if it get's emailed to outside companies, they won't see who our client is.
Franco
GMT +08:00
