Message 1 of 17
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Forum
I have a part file where I can change the length of a part.
The part also has a simple iLogic code with different cases. The cases select what extrusions should be active or suppressed.
I want to make a Form where I choose the length and Case.
Then be able to press save (save as), The length and selected case should be used as a extensions behind the original file name.
I don't think this should be a complicated code but I'm very new to Ilogic.
This is the code I use to Select the case:
Feature.IsActive("Ø200 CONT") = False Feature.IsActive("Ø200 DOWN") = False Feature.IsActive("Ø200 UP") = False Feature.IsActive("Ø250 CONT") = False Feature.IsActive("Ø250 DOWN") = False Feature.IsActive("Ø250 UP") = False Select Case FixedUnit_Curve Case "Ø200 CONT" Feature.IsActive("Ø200 CONT") = True Case "Ø200 DOWN" Feature.IsActive("Ø200 DOWN") = True Case "Ø200 UP" Feature.IsActive("Ø200 UP") = True Case "Ø250 CONT" Feature.IsActive("Ø250 CONT") = True Case "Ø250 DOWN" Feature.IsActive("Ø250 DOWN") = True Case "Ø250 UP" Feature.IsActive("Ø250 UP") = True End Select iLogicVb.UpdateWhenDone = True
I use this code to open the form when opening the file.
iLogicForm.Show("Fixed Unit Curve and Length")
Let me know if you guys need anymore info!
Thanks 🙂
