Save option
Save option
tomislav.peran
Save option
tomislav.peran
I would like to save the drawing in the same location as the assembly from which it is created after it is created, but I do not seem to find a way to do it.
Is that doable via code or does the user need to save the drawing manually the first time after its creation?
I do not want to use SaveAs with the written location in the code.
Tom
Daan_M
Try something like this:
Dim oDoc As AssemblyDocument = ThisDoc.Document
oPath = ThisDoc.Path
Dim oDrawingDoc As DrawingDocument
Dim oDrawingDocName As String = "testdrawing.dwg"
oTemplateLoc = "C:\Data\TestTemp.dwg"
oDrawingDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, oTemplateLoc, True)
oDrawingDoc.SaveAs(oPath & "\" & oDrawingDocName, True)
oDrawingDoc.Close
tomislav.peran
Hi Daan_M,
That should work in my opinion but It does not in my document.
I will try later to test some more. Thanks for the help though!
Daan_M
@tomislav.peran If you show the error that comes up we can look further into it.
It works fine for me so i think it's dependant on the rest of your code.
tomislav.peran
Hi Daan_M,
The code you placed works indeed. I have tested it in another assembly.
But this is the code I have in my assy and there it does not work for some reason...I am copying only the first part. The rest of the code places views on the sheet 1 which is not that interesting here.
Error is general....parameter is not correct...
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
oExt = Right(oDoc.FullDocumentName, 3) 'get file extension
Dim oDrawingDocName As String = User_parameter_1
Try 'to open the drawing
	ThisApplication.Documents.Open _
	(ThisDoc.PathAndFileName(True).Replace(oExt, "idw"))
	Return 'exit rule
Catch
End Try
oDrawingDoc = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, "C:\Inventor\template.idw", True) oDrawingDoc.SaveAs(oPath & "\" & oDrawingDocName, True) oDrawingDoc.Activate() Dim oSheet As Sheet
oSheet = oDrawingDoc.Sheets.Item(1) Dim oPoint1 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(20, 20)
tomislav.peran
Ah I have found the mistake...forgot the extension...
Dim oDrawingDocName As String = User_parameter_1 & ".idw"
The first mistake I did was running the code from the template that the drawing uses. That does not work.
You placed the code in assembly and that works.
Thanks Daan for the help!
Tom
brandontsche
Community Visitor
Community Visitor
G
