Ilogic If conditions false
kpk7VYPK
kpk7VYPK
Hi I am new to ilogic and i am trying to figure out how to get the part number iproperty to be blank if none of the conditions are true. This is what i have so far:
'ø80
If InnerDiameter = 80 mm    And thk = 0.75 mm  And L = 500 mm  Then
	iProperties.Value("Project", "Part Number") = "130001820003"
	ElseIf thk = 1 mm And L = 1000 mm Then
	iProperties.Value("Project", "Part Number") = "130001820002"
	ElseIf thk = 0.75 mm And L = 2000 mm Then
	iProperties.Value("Project", "Part Number") = "130001820001"
'ø100
If InnerDiameter = 100 mm     And thk = 0.75 mm   And L = 500 mm   Then
	iProperties.Value("Project", "Part Number") = "130001820006"
	ElseIf thk = 0.75 mm And L = 1000 mm Then
	iProperties.Value("Project", "Part Number") = "130001820005"
	iProperties.Value("Project", "Part Number") = "130001820004"
	ElseIf thk = 1.5 mm And L = 500 mm Then
	iProperties.Value("Project", "Part Number") = "130001810120"
	ElseIf thk = 1.5 mm And L = 1000 mm Then
	iProperties.Value("Project", "Part Number") = "130001810121"
	ElseIf thk = 1.5 mm And L = 2000 mm Then
	iProperties.Value("Project", "Part Number") = "130001810122"
JelteDeJong
You could make the part number nothing and change it if needed. I guess that will result in what you are looking for.
iProperties.Value("Project", "Part Number") = ""
'ø80
'ø100
 to
Jelte de Jong
Blog: hjalte.nl - github.com
kpk7VYPK
Of course! thank you.
