save copy as idw to dwg yielding zip file
on 9-2-15 my ilogic code:
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 20737 StartFragment: 314 EndFragment: 20705 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
' Set a reference to the DWG translator add-in. Dim oDWGAddIn As TranslatorAddIn Dim i As Long For i = 1 To ThisApplication.ApplicationAddIns.count If ThisApplication.ApplicationAddIns.Item(i). _ ClassIdString = _ "{C24E3AC2-122E-11D5-8E91-0010B541CD80}" Then oDWGAddIn = ThisApplication. _ ApplicationAddIns.Item(i) Exit For End If Next ' Check to make sure the add-in is activated. If Not oDWGAddIn.Activated Then oDWGAddIn.Activate End If ' Create a name-value map to supply information to the translator. Dim oNameValueMap As NameValueMap = ThisApplication. _ TransientObjects.CreateNameValueMap Dim strIniFile As String = "O:\Templates\INVENTOR\EXPORT TEMPLATES\" & iProperties.Value("CUSTOM", "INI FILE") ' Create the name-value that specifies the ini file to use. Call oNameValueMap.Add _ ("Export_Acad_IniFile", strIniFile) ' Create a translation context and define ' that we want to output to a file. Dim oContext As TranslationContext = ThisApplication.TransientObjects. _ CreateTranslationContext oContext.Type = kFileBrowseIOMechanism If Not System.IO.DIRECTORY.Exists(iProperties.Value("CUSTOM", "DWG PATH")) Then System.IO.DIRECTORY.CREATEDIRECTORY(iProperties.Value("CUSTOM", "DWG PATH")) End If ' Define the type of output by specifying the filename. Dim oOutputFile As DataMedium = ThisApplication. _ TransientObjects.CreateDataMedium oOutputFile.FileName = iProperties.Value("CUSTOM", "DWG PATH") & iProperties.Value("CUSTOM", "DWG FILE") If System.IO.FILE.Exists(iProperties.Value("CUSTOM", "DWG PATH") & iProperties.Value("CUSTOM", "DWG FILE")) Then System.IO.FILE.DELETE(iProperties.Value("CUSTOM", "DWG PATH") & iProperties.Value("CUSTOM", "DWG FILE")) End If ' Call the SaveCopyAs method of the add-in. Call oDWGAddIn.SaveCopyAs _ (ThisApplication.ActiveDocument, _ oContext, _ oNameValueMap, _ oOutputFile)
saved a copy of my file to a specific sub folder as DWG
on 9-3-15 it saved it inside a zip file
I had already followed cathy's advice on editing the registry found here:
any advice to fix this now?
