save copy as idw to dwg yielding zip file
BWMcDowell
BWMcDowell
on 9-2-15 my ilogic code:
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 20737 StartFragment: 314 EndFragment: 20705 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
' Set a reference to the DWG translator add-in.
Dim oDWGAddIn As TranslatorAddIn
Dim i As Long
For i = 1 To ThisApplication.ApplicationAddIns.count
    If ThisApplication.ApplicationAddIns.Item(i). _
    ClassIdString = _
    "{C24E3AC2-122E-11D5-8E91-0010B541CD80}" Then
        oDWGAddIn = ThisApplication. _
        Exit For
    End If
Next
' Check to make sure the add-in is activated.
If Not oDWGAddIn.Activated Then
    oDWGAddIn.Activate
End If
' Create a name-value map to supply information to the translator.
Dim oNameValueMap As NameValueMap = ThisApplication. _
    TransientObjects.CreateNameValueMap
Dim strIniFile As String = "O:\Templates\INVENTOR\EXPORT TEMPLATES\" & iProperties.Value("CUSTOM", "INI FILE")
' Create the name-value that specifies the ini file to use.
Call oNameValueMap.Add _
    ("Export_Acad_IniFile", strIniFile)
' Create a translation context and define ' that we want to output to a file.
Dim oContext As TranslationContext = ThisApplication.TransientObjects. _
    CreateTranslationContext
oContext.Type = kFileBrowseIOMechanism
    If Not System.IO.DIRECTORY.Exists(iProperties.Value("CUSTOM", "DWG PATH")) Then
    System.IO.DIRECTORY.CREATEDIRECTORY(iProperties.Value("CUSTOM", "DWG PATH"))
    End If
' Define the type of output by specifying the filename.
Dim oOutputFile As DataMedium = ThisApplication. _
    TransientObjects.CreateDataMedium
    oOutputFile.FileName = iProperties.Value("CUSTOM", "DWG PATH") & iProperties.Value("CUSTOM", "DWG FILE")
    If System.IO.FILE.Exists(iProperties.Value("CUSTOM", "DWG PATH") & iProperties.Value("CUSTOM", "DWG FILE")) Then
    System.IO.FILE.DELETE(iProperties.Value("CUSTOM", "DWG PATH") & iProperties.Value("CUSTOM", "DWG FILE"))
    End If
' Call the SaveCopyAs method of the add-in.
Call oDWGAddIn.SaveCopyAs _
    (ThisApplication.ActiveDocument, _
          oContext, _
          oNameValueMap, _
          oOutputFile)
saved a copy of my file to a specific sub folder as DWG
on 9-3-15 it saved it inside a zip file
I had already followed cathy's advice on editing the registry found here:
http://forums.autodesk.com/t5/inventor-general-discussion/save-copy-as-acad-dwg-zip-file/td-p/223026...
any advice to fix this now?
BWMcDowell
mine did that suddenly recently starting last month
the work around is manually export first
it was caused by my network drives not connecting properly
when I opened a file in autocad here were red x's on network drives
changed a few things to get it to work again :
disabled power saver on my nic
disabled intel pro service
changed group policy to wait until network has initialized
set autocad services to delayed start
hope this helps
