Save button with extra file type saving
Mustang69
Mustang69
Hello
I working alot with sheetmetal products and in my IDW file I allways placing an "Flat pattern" view.
The problem for me is that the workers in the machine shop can't work with this IDW format.
The machines i talking about is punching machines like Trumpf and Amada etc, etc.....Even modern laser machines cant read IDW files.
These machines need DXF or DWG format for importing into their "Nesting" program
Like this one. http://www.jetcam.com/expert_punching.htm
Ok so now I manually do "Save as" DXF everytime I do an IDW files.
This is not good and several times we have missed updates because I done minor changes in a parts and missed saving to DXF.
Is there a way to make a "Save" button that both saves an IDW and DXF file at the same time?
I have tried to only work with Inventor DWG but the Nesting program can't read that either.
adam.nagy
Autodesk Support
Autodesk Support
There are multiple ways to do that. Probably the easiest one is to write a VBA function and hook it up to a button.
You can use DataIO for the DXF export: http://adndevblog.typepad.com/manufacturing/2012/05/exporting-flat-pattern-as-dwgdxf.html
Cheers,
Adam Nagy
Autodesk Platform Services
