save as with "place iLogic component"
Storgaarden
Storgaarden
Hi
I am working with iLogic, and made a part with a few basic rules. I set up a form so it appears when place iLogic component in an assembly. This random generates a name for the file (Inventor is currently set up to give consecutive numbers, but I want to be able to name the parts so it will get easier to identify them). Is it possible to either get a "save as", so it is possible to name the part on your own, or even make it autogenerate a name based on the original part name + the data input from the iLogic form?
I am quite new to iLogic, so I dont know if this is even possible?
Thanks in advance
/J. Storgaard
"You were good, kid, really good, but as long as I'm around
you'll always be second best, see."
Inventor 2014
Win 7 Pro, 64 bit
Intel i5-2400 3.10 GHz
14 GB RAM
Sergio.Bertino
Autodesk Support
Autodesk Support
It would be great if you could post some sample files and some screenshot to better understand what you want to get.
Sergio Bertino
MFG Technical Support Specialist
