Save & replce code to open ”place from vault” filedialog instead of a regular one.
e2000773
Message 1 of 1
e2000773
Hello how would this code be modified to open ”Place from Vault” - filedialog instead of the regular one in the code. Alternatively it could open the ”Place” -filedialog, because that has the small icon to access Place from Vault.  Idea is to Place from Vault and this code runs and I can choose a new name and save location to a desired place for the model.
I know this code:
ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyPlaceComponentCmd").Execute
opens a correct filedialog, but how would I modify this code to replace that regular filedialog (or replace with a place from vault filedialog):
'Create a new FileDialog object.
    Dim FileDlg As Inventor.FileDialog
  	ThisApplication.CreateFileDialog(FileDlg)
    'Define the filter to select part and assembly files or any file.
    FileDlg.Filter = "Inventor Files (*.ipt)|*.ipt|All Files (*.*)|*.*"
    'Set the title for the dialog.
    FileDlg.DialogTitle = "Save Copy As Utility"
    'Set the initial directory that will be displayed in the dialog.
    FileDlg.InitialDirectory = "C:\Users\Enter Name Here"
	FileDlg.ShowOpen
	'Deal with a canceled file Selection
 	If FileDlg.FileName = Nothing  Then Return
    'Set a reference to the assembly component definintion.
    Dim AsmCompDef As AssemblyComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
	'Post the filename To the Private Event queue.
   	ThisApplication.CommandManager.PostPrivateEvent(Inventor.PrivateEventTypeEnum.kFileNameEvent, FileDlg.FileName)
	'Get the control definition for the Place Component command.
    Dim ctrlDef As Inventor.ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyPlaceComponentCmd")
	'Execute the command.
    ctrlDef.Execute2(True)
For Each Occ As ComponentOccurrence In AsmCompDef.Occurrences
	If Occ.Definition.Document.FullFileName = FileDlg.FileName Then
		'Select the occurrence just added
		ThisApplication.CommandManager.DoSelect(Occ)
Next
'Get the command (Button in the productivity tab)
ctrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyBonusTools_SaveAndReplaceComponentCmd")
ctrlDef.Execute()
Replies (0)
