BOM.GetPartNumberMergeSettings2
ThomasRambach
Advisor Advisor
ThomasRambach
Whenever I use the following:
Inventor.AssemblyDocument ASMdoc = (Inventor.AssemblyDocument)mDoc;
AssemblyComponentDefinition oAsmCompDef = ASMdoc.ComponentDefinition;
oAsmCompDef.BOM.GetPartNumberMergeSettings2(out bool boolMergeEnabled, out string[] strMergeExcludeList, out bool boolMergeInstanceRows);
It always results in an error with GetPartNumberMergeSettings2 like:
System.NullReferenceException: 'Object reference not set to an instance of an object.'
I'm not sure why this is. It's a normal Inventor assembly file each time. What am I doing wrong?
Curtis_Waguespack
Hi @ThomasRambach ,
Maybe you're not setting the string array?
This runs without error
Dim ASMdoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oAsmCompDef As ComponentDefinition = ASMdoc.ComponentDefinition
Dim strings = New String() {"1111", "2222" }
oAsmCompDef.BOM.GetPartNumberMergeSettings2(True, strings, False)
    AssemblyDocument ASMdoc = Inventor.ActiveDocument;
    var strings = new string[] { "1111", "2222" };
    oAsmCompDef.BOM.GetPartNumberMergeSettings2(true, strings, false);
ThomasRambach
@Curtis_Waguespack  Wouldn't that only be needed if I'm "Setting" and not "Getting"? It's always looking for the the "Out" on Get.
Curtis_Waguespack
@ThomasRambach
Ahhh, I think you're right. I only took a quick look at this earlier. I'll try to have another look later.
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-D7361CFC-43FF-4108-8CA0-0110D05DDD23
chandra.shekar.g
Autodesk Support
Autodesk Support
@ThomasRambach,
The C# code sample for GetPartNumberMergeSettings2 API method is as below:
AssemblyDocument oDoc =(AssemblyDocument) m_inventorApp.ActiveDocument;
AssemblyComponentDefinition oDef = oDoc.ComponentDefinition;
BOM oBom = oDef.BOM;
bool bMerged = false;
string[] sExcludeList = new string[] { };
bool bMergeInsRows = false;
oBom.GetPartNumberMergeSettings2(out bMerged, out sExcludeList,out bMergeInsRows);
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
