Save & Replace as Assembly components
NachoShaw
Advisor Advisor
NachoShaw
Hey
I have a need to save & replace every sub assembly / part in my top level assembly and im coming up with some difficulties. First, a summary.
All of the Assembly components are from an imported file. I am not saving the assembly file as i dont need it. I am importing it, processing the names of the components inside the assembly then i need to save & replace each component out as a new name with the last one being the top level assembly.
What is the best approach? I am using Active EditDocument whenever i come to a sub assembly so that i can process the sub parts but it doesnt seem to be working for me.. I am using the DocumentDescriptor.ReplaceReference
My objective is to have a saved assembly of the exact same structure but with all components having a new name
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
yan.gauthier
I just did the same kind of macro in order to rename imported standard assemblies (e.g.: Festo cylinder) to a standard format for our file standards. In order to replace reference in sub assemblies, you might need to enter each of them in edit mode.
From one assembly, I copy, rename and then replace using this method :
oDoc.SaveAs savePath & ComponentName & ".iam", False
'redo reference of all sub components
For Each refDoc In oDoc.AllReferencedDocuments
    If TypeOf refDoc Is PartDocument Then
        fileExtension = ".ipt"
    ElseIf TypeOf refDoc Is AssemblyDocument Then
        fileExtension = ".iam"
    'increment part suffix (e.g.: XXXXX_1, XXXXX_2, etc...)
    count = count + 1
    newFullFileName = savePath & ComponentName & "_" & count & fileExtension
    'if file already exists, make a new one based on the first
    If refDoc.FileSaveCounter > 0 Then
        'copy file once, reuse then
        If Not fso.fileExists(newFullFileName) Then
            fso.CopyFile refDoc.Fullfilename, newFullFileName, False '.CopyFile(Source, Dest [,Overwrite (True/False)]
        Set DocDescriptor = oDoc.ReferencedDocumentDescriptors.item(refDoc.Fullfilename)
        DocDescriptor.ReferencedFileDescriptor.ReplaceReference newFullFileName
    Else
        'Change file name to desired location
        refDoc.Fullfilename = newFullFileName
    'Change document display name
    refDoc.DisplayName = ComponentName & "_" & count
Next refDoc
odoc.update2 true
yan.gauthier
Also keep in mind that replaceReference works only if part share the same internal name (i.e.: they are a copy of one another)
