- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello all,
I found a code to Save all sheetmetal parts from assembly to DXF. I make some changes to apear below the drawing parts, Material and thickness. But I whant to put the QTY also? Can I help me to make the necessary changes in the code?
Thanks in advance
Code:
Sub Main
'iLogic Code by Jhoel Forshav - originally posted at https://clintbrown.co.uk/ilogic-export-all-flat-patterns-to-one-dxf
'Check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("This rule can only run from an Assembly file", "DXF-creator", MessageBoxButtons.OK, MessageBoxIcon.Error)
Exit Sub
End If
'Dim the active document as AssemblyDocument
Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
'Make sure the assembly is saved
If oDoc.FullFileName = ""
MessageBox.Show("Please save the Assembly before running this rule.", "DXF-creator", MessageBoxButtons.OK, MessageBoxIcon.Information)
Exit Sub
End If
'Get the assembly filename without extension
Dim oAsmName As String = System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName)
'Get the assembly filepath
Dim oPath As String = System.IO.Path.GetDirectoryName(oDoc.FullFileName)
'Get the parts only BOM.
Dim oBOM As BOM = oDoc.ComponentDefinition.BOM
'Make sure Parts Only is activated
oBOM.PartsOnlyViewEnabled = True
'Parts only will be last BomView (difficult to get by name since it's different depending on your language)
Dim oBOMview As BOMView = oBOM.BOMViews.Item(oBOM.BOMViews.Count)
'Set a reference to the TransientGeometry object
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
'oX and oY will be used to create points for view placement
Dim oX As Double = 0
Dim oY As Double = 0
'Create the Baseview options to place flatpattern-views
Dim oBaseViewOptions As NameValueMap
oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap
oBaseViewOptions.Add("SheetMetalFoldedModel", False)
'Set a variable for the drawing document
Dim oDrawing As DrawingDocument
'Create a String to return a message if any SM-parts are not saved
Dim unsavedSmParts As String = ""
Dim i As Integer = 1
Dim oInfo As String = ""
'Traverse Parts Only BOM
For Each oRow As BOMRow In oBOMview.BOMRows
Try
'Get the component definition for the part
Dim oDef As ComponentDefinition = oRow.ComponentDefinitions(1)
'Check if the part is SheetMetal
If TypeOf (oDef) Is SheetMetalComponentDefinition
'Set a reference to the partdocument
Dim smPartDoc As PartDocument = oDef.Document
'Check if the part is saved
If smPartDoc.FullFileName = "" Then
If unsavedSmParts = "" Then unsavedSmParts = "The fallowing SM-documents were not saved and therefore " & _
"no drawingviews were created:" & vbCrLf
unsavedSmParts = unsavedSmParts & vbCrLf & oDef.Document.DisplayName
Continue For
End If
'Create flatpattern if it doesn't already exist
If Not oDef.HasFlatPattern
oDef.Unfold()
oDef.FlatPattern.ExitEdit()
End If
'Create the drawing if it doesn't already exist
If oDrawing Is Nothing
oDrawing = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, _
, False)
'Set the drawings length units to the same as the assemblys length units
oDrawing.UnitsOfMeasure.LengthUnits = oDoc.UnitsOfMeasure.LengthUnits
End If
'Set a reference to the drawing sheet
Dim oSheet As Sheet = oDrawing.ActiveSheet
'Create the flatpattern view
Dim oView As DrawingView = oSheet.DrawingViews.AddBaseView(smPartDoc, oTG.CreatePoint2d(oX, oY), 1 _
, ViewOrientationTypeEnum.kDefaultViewOrientation, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle, _
"FlatPattern", , oBaseViewOptions)
oView.Name = smPartDoc.DisplayName & vbNewLine & "Espessura: " & smPartDoc.ComponentDefinition.Thickness.Expression _
& vbNewLine & "Material: " & smPartDoc.PropertySets("Design Tracking Properties")("Material").Value
oView.ShowLabel = True
'Set the position with our oX and oY
oView.Position = oTG.CreatePoint2d(oView.Position.X + oView.Width / 2, oView.Position.Y)
'Move oX to place the next view to the right of this one
oX = oView.Left + oView.Width + 1
'Remove the bend lines of the view
RemoveBendLines(oView, oDef.FlatPattern)'You could comment out this line to keep bend lines
oInfo = oInfo & "Here" & If (i = 1, "", vbCrLf) & i & ". " & smPartDoc.PropertySets.Item("Design Tracking Properties"). _
Item("Part Number").Value
i += 1
'Close the part
smPartDoc.Close(True)
End If
Catch Ex As Exception
MsgBox(Ex.Message)
End Try
Next
If oDrawing IsNot Nothing
'Create the save location string for the DXF
Dim oDXFName As String = oPath & "\" & oAsmName & "_FlatPatterns.dxf"
'Save the DXF
oINI = "C:\Users\LF\Desktop\Configuracoes Inventor LF\config Inventor\exportdxf.ini" 'Specify your INI file location here (eg C:\TEMP\DXF Export.ini)
If oINI = "" Then
MessageBox.Show("You need to specify an INI file location in the code - Look for oINI and set the path", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
End If
SaveDXF(oDrawing, oDXFName, oINI)
'Create the save location string for the information txt
Dim oInfoName As String = oPath & "\" & oAsmName & "_FlatPatterns.txt"
'Create the txt
CreateTXT(oInfo, oInfoName)
End If
'Close the drawing
oDrawing.Close
'return information about any unsaved parts
If unsavedSmParts <> "" Then _
MessageBox.Show(unsavedSmParts, "Some parts were not saved", _
'Update the assembly (could be dirty if any flatpatterns were created)
oDoc.Update
End Sub
Sub SaveDXF(oDrawing As DrawingDocument, oFileName As String, oIniFile As String)
'Set a reference to the DFX translator
Dim DXFAddIn As TranslatorAddIn
DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
'Create translation context
Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
'Create options for the translation
Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
'Create a DataMedium object
Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
'Set the options (which .ini-file to use)
If DXFAddIn.HasSaveCopyAsOptions(oDrawing, oContext, oOptions) Then
oOptions.Value("Export_Acad_IniFile") = oIniFile
End If
'Set the filename property of the DataMedium object
oDataMedium.FileName = oFileName
Try
'Try to save the DXF
DXFAddIn.SaveCopyAs(oDrawing, oContext, oOptions, oDataMedium)
MessageBox.Show("Dxf saved to: " & oFileName, "DXF SAVED", MessageBoxButtons.OK, MessageBoxIcon.Information)
Catch
MessageBox.Show("Couldn't save dxf!", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
End Try
End Sub
Sub RemoveBendLines(oView As DrawingView, oFlattPattern As FlatPattern)
'Get all the bend edges from the FlatPattern
Dim oBendEdgesUp As Edges = oFlattPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendUpFlatPatternEdge)
Dim oBendEdgesDown As Edges = oFlattPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendDownFlatPatternEdge)
For Each oEdge As Edge In oBendEdgesUp
'Get the curves representing these edges in the drawing view
For Each oCurve As DrawingCurve In oView.DrawingCurves(oEdge)
For Each oSegment As DrawingCurveSegment In oCurve.Segments
'Set visibility to false
oSegment.Visible = False
Next
Next
Next
For Each oEdge As Edge In oBendEdgesDown
Next
Next
Next
End Sub
Sub CreateTXT(oText As String, oFileName As String)
Dim oTxtWriter As System.IO.StreamWriter = System.IO.File.CreateText(oFileName)
oTxtWriter.WriteLine(oText)
oTxtWriter.Close()
End Sub
