Sample code for Creating assembly from the available parts
2019mmp003
2019mmp003
Hello everyone. Hope you are doing good. I have created parts(hollow cylinders) and saved them in a folder, I want to make an assembly using those parts, Such that they must be placed one inside other concentrically. I want to place those parts into the assembly doc using place features and then add concentric constraint such that there top and bottom faces should also be at same level. If anyone could help me with the sample code it would be great. Thanks.
JelteDeJong
you can use this as a sample. run it in an assembly. it will add 2 parts. then you need to select to edges for the constraint. Then the constraint ismade.
Dim doc As AssemblyDocument = ThisDoc.Document
Dim otg As TransientGeometry = ThisApplication.TransientGeometry
Dim matrix As Matrix = otg.CreateMatrix()
Dim occ1 = doc.ComponentDefinition.Occurrences.Add("D:\forum\tube.ipt", matrix)
occ1.Grounded = True
matrix.SetTranslation(otg.CreateVector(150, 0, 0))
Dim occ2 = doc.ComponentDefinition.Occurrences.Add("D:\forum\tube2.ipt", matrix)
Dim edge1 As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeCircularFilter, "Select first edge")
Dim edge2 As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeCircularFilter, "Select second edge")
doc.ComponentDefinition.Constraints.AddInsertConstraint(edge1, edge2, False, 0.0)
Jelte de Jong
Blog: hjalte.nl - github.com
