Running iLogic before Vault Check In
t.bennett
t.bennett
I would like create a rule that will run when Check In is selected that will add a watermark to the drawing for ease of identifying where a document is saved when looking at the print on the floor. I'm aware that you can add the path the file is saved to on the computer but I would rather not display the full path as the file could change location in the Vault and then giving a direct location may confuse some. Most of the discussions I have found about rules during Check In usually just die off and have no resolution and the only other I have found applied to AutoCAD.
ADSKDJW4
Hello @t.bennett,
I will ask the forum moderator to move this post to the Inventor Customization Forum where this question is better served.
Best Regards,
Don
