Asses AutoCAD dwg Custom properties with iLogic
RasmusBredal
RasmusBredal
Hi All
I have a drawing where there is a ReferencedOLE link to C: \ temp \ 4217901.dwg.
I would like to read some Custom Properties into my Inventor drawing.
fx System
I can get the ReferencedOLEFile path with this code:
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
If oDoc.ReferencedOLEFileDescriptors.Count = 0 Then
    MessageBox.Show("There aren't any OLE references in this document.", "OLE - iLogic")
    Exit Sub
Dim aOLERefs() As ReferencedOLEFileDescriptor
ReDim aOLERefs(oDoc.ReferencedOLEFileDescriptors.Count - 1)
Dim iRefCount As Integer
iRefCount = oDoc.ReferencedOLEFileDescriptors.Count
Dim i As Integer
For i = 1 To iRefCount
    aOLERefs(i - 1) = oDoc.ReferencedOLEFileDescriptors.Item(i)
	MessageBox.Show(aOLERefs(i - 1).FullFileName, "OLE Path")
Next
Is it possible to read Custom Properties with System.io.file?
pball
You can open a file in the background to access it's properties.
Dim invDoc As Document
    Set invDoc = ThisApplication.Documents.Open("c:\filename.ipt",false)
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
RasmusBredal
Hi pball
Thanks I had not through of this. 😉
Unfortunately, can Inventor not open ÁutoCAD dwg in the background....
Next step is how I get asses to the open dwg file properties..
The iLogic rule is running from a idw file.
Have tried the following:
SyntaxEditor Code Snippet
    invDoc = ThisApplication.Documents.Open(oDWGFile, False)
    'define the property set
    customPropertySet = invDoc.PropertySets.Item("Inventor User Defined Properties")
    Dim oSystem As String
    Try
oSystem = customPropertySet.Item("System")
Catch
End Try
