Run rule from subassembly A in subassembly B in the same assembly
07:16 AM
Hi!
I have an assembly which only contains an iLogic form and some rules (Assy1). With the form/rules I can search and place other assemblies (Assy2) (in my case a simple frame).
What I am trying to do is place Assy1 in a new assembly, so that I can choose a frame which will also be a subassembly (later on, other components will be placed on the frame, and so far things work). Next thing I want to do is change the Part Number of Assy2 by running a rule from the form of Assy1.
I've tried iProperties.Value etc, but that only works if I place Assy2 in Assy1.
My question: Is there a command or something to do this?
(also: I'm not that skilled with iLogic)
Thanks in advance 🙂
Regards, Britt
