I-Logic Boolean
I-Logic Boolean
didin.suryadi6JREK
I-Logic Boolean
didin.suryadi6JREK
HI
I created short i-logic to take some shortcut from Custome Iproperties, on Boolean option with Yes/No input text on text box the result is always came out with Yes, Cant change to No.
Below the i-logic form.
Dim propertyName3 As String = "Laser Cut"
Dim propertyValue3 As Boolean = True
InputBox ("Laser Cut:", "Set Property", "Yes")
Try
	prop = customPropertySet.Item(propertyName3)
Catch
	customPropertySet.Add(propertyValue3, propertyName3)
End Try
If propertyValue3 = True Then
	iProperties.Value("Custom", propertyName3) = True
Else If propertyValue3 = False Then
	iProperties.Value("Custom", propertyName3) = False
 When i input No in inputbox it always come up with Yes
Rgds
Didin
JhoelForshav
@didin.suryadi6JREK
You're not using the value from the inputbox as the code is written now...
Try this 🙂
Dim valString As String = InputBox("Laser Cut:", "Set Property", "Yes")
Dim propertyValue3 As Boolean = If (valString = "Yes", True, False)
Try
Catch
	prop = customPropertySet.Add(propertyValue3, propertyName3)
End Try
iProperties.Value("Custom", propertyName3) = propertyValue3
JhoelForshav
The entire code can however be rewritten to one single line though, since iProperties.Value creates the property if it doesn't already exist.
iProperties.Value("Custom", "Laser Cut") = If (InputBox("Laser Cut:", "Set Property", "Yes") = "Yes", True, False)
didin.suryadi6JREK
Thank You sir, you're the best
