Run Rule, create new .iam, Close original .iam
J.VandeMerckt
Message 1 of 12
J.VandeMerckt
Hi everyone
I have a Ilogic code which makes a new Assembly and opens that assembly.
I'm trying to setup a rule that closes the original assembly and forces it to not save.
I tried a bunch of codes but I can't figure out how to set it up.
Right now I'm trying this rule:
			Dim asmDoc As Document = currentfilename
			asmDoc.Close(False)
 I'm getting this error:
Error in rule: XP200Replace, in document: TB4001-1750-FU1CYE - Test.iam
Unable to cast object of type 'System.String' to type 'Inventor.Document'.
Can anyone help?
Replies (11)
Message 2 of 12
A.Acheson
Hi @J.VandeMerckt
The error message is correct you can't assign a string value to document. See link here to document object in API help, scroll to the bottom and look at the accessed from paragraph. Here you will get all the objects you can access the document object from.
You either need to have the document object earlier in your code using "ThisApplication.ActiveDocument" or "ThisDoc.Document" or retrieve it from memory or open it directly using "ThisApplication.Documents.Open(currentfilename,True)
Regards
Alan
Message 3 of 12
J.VandeMerckt
Hi Acheson
I'm not quite sure how to use these rules.
I've only been trying iLogic for a short time and have never been thought how to program.
Could you try to explain a bit more?
Thank you
Message 4 of 12
A.Acheson
At the start of the rule you are in the assembly document and this is the one you want to close so use the following.
Dim asmDoc As AssemblyDocument = ThisApplication.ActiveDocument
asmDoc.Close(False)
 Can you share the complete rule? If you are switching active document the above rule will  close the wrong document. If you want to be sure you have the right one before closing use the below messagebox to check the filepath.
Messagebox.Show(asmDoc.FullFileName)
Regards
Alan
Message 5 of 12
J.VandeMerckt
Hi Acheson
At the end of my code.
A new document opens indeed. This document has the same name but with some extra info at the back.
Here the complete rule:
Sub main
	If TypeOf ThisDoc.Document Is AssemblyDocument Then
		Dim oAssDoc As AssemblyDocument = ThisDoc.Document
		Dim fso As Object = ThisApplication.FileManager.FileSystemObject
		Dim oPartOcc As ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, _
																					"Select your part...(Press ESC to cancel)")
		If oPartOcc Is Nothing Then Exit Sub
		If TypeOf oPartOcc.Definition Is PartComponentDefinition Then
			Dim oPartDef As PartComponentDefinition = oPartOcc.Definition
			Dim oPartDoc As PartDocument = oPartDef.Document
			Dim oUseParams As UserParameters = oPartDef.Parameters.UserParameters
			Dim sLength As String = InputBox("Enter the length parameter:", "Parameter.", oUseParams.Item("FixedUnit_Length").Expression)
			'Clean sLength so only numbers are left over
			Dim sLengthCleaned As String
			For i As Integer = 0 To sLength.Length - 1
				If Char.IsDigit(sLength(i)) Or sLength(i) = "."c Then
 					 sLengthCleaned &= sLength(i)
				End If
 			Next
			Dim newLength As Double = Double.Parse(sLengthCleaned)
			If Not Double.TryParse(sLengthCleaned, newLength) Then Exit Sub
			Dim newCurve As String = GetNewParam(oUseParams, "FixedUnit_Curve", oPartDoc.DisplayName)
			If newCurve Is Nothing Then Exit Sub
			Dim sPath As String = System.IO.Path.GetDirectoryName(oPartDoc.FullFileName)
			Dim sFullName As String = sPath & "\" & System.IO.Path.GetFileNameWithoutExtension(oPartDoc.FullFileName) & " - " & Strings.Mid(newCurve, 2, Strings.Len(newCurve) - 2) & " - L" & newLength & "mm.ipt"
			If Not System.IO.File.Exists(sFullName) Then
				fso.copyFile(oPartDoc.FullDocumentName, sFullName, True)
				oPartOcc.Replace(sFullName, True)
				Dim oNewPart As PartDocument = GetNewComponent(oAssDoc, sFullName)
				Dim oNewParams As UserParameters = oNewPart.ComponentDefinition.Parameters.UserParameters
				If sActLength <> newLength Then ChangeParam(oNewParams, "FixedUnit_Length", newLength)
				If sActCurve <> newCurve Then ChangeParam(oNewParams, "FixedUnit_Curve", newCurve)
				oNewPart.Save()
			Else
				MessageBox.Show("Part Already exist", "Error")
			End If
			oAssDoc.Update()
			currentfilename = ThisDoc.FileName(False)
			'filepath same as the current ipt
			SetTheFilePathHere = ThisDoc.Path
			'Set the new file name
			SetTheFilenameHere = currentfilename & " - " & Strings.Mid(newCurve, 2, Strings.Len(newCurve) - 2) & " - L" & newLength & "mm"
			'Use the CommandManager object to execute a private event that sets the file name and path.
			ThisApplication.CommandManager.PostPrivateEvent(kFileNameEvent, SetTheFilePathHere &"\" & SetTheFilenameHere & ".iam")
			'Use the ControlDefinitions object to execute a command that saves the file with the new name and path.
			Dim oCtrlDef
			oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AppFileSaveCopyAsCmd")
			oCtrlDef.Execute
			'Close original file without saving
			' Get a reference to a specific assembly
			asmDoc.Close(False)
			'Open new file
			ThisDoc.Launch(SetTheFilePathHere & "\" & SetTheFilenameHere & ".iam")
		Else
			MessageBox.Show("Select component is not PartDocyment!", "Error",MessageBoxButtons.OK,MessageBoxIcon.Error)
		End If
	Else
		MessageBox.Show("Active document is not AssemblyDocyment!", "Error",MessageBoxButtons.OK,MessageBoxIcon.Error)
	End If
End Sub
Private Function GetNewParam(oUseParams As UserParameters, sNameParam As String, sPartName As String) As String
	Dim sListParams As New List(Of String)
	Dim sActParam As String
	Dim iActParam As Integer
	For Each oParam As Inventor.Parameter In oUseParams
		If oParam.Name = sNameParam Then
			sActParam = oParam.Expression
			sListParams.AddRange(oParam.ExpressionList.GetExpressionList())
			Exit For
		End If
	Next
	If sActParam IsNot Nothing Then
		sListParams.Sort
		iActParam = sListParams.IndexOf(sActParam)
		If iActParam < 0 Then iActParam = 0
	Else
		MessageBox.Show("The selected component is missing a parameter: " & sNameParam, "Error!",MessageBoxButtons.OK,MessageBoxIcon.Error)
		Return Nothing
	End If
	Dim newParam As String = InputListBox(sPartName, sListParams, sListParams(iActParam), _
											Title := "List parameters.", ListName := "Select " & sNameParam & ":")
	If newParam Is Nothing Then Return Nothing
	Return newParam
End Function
Private Function ChangeParam(oUseParams As UserParameters, sNameParam As String, newExpr As String)
			oParam.Expression = newExpr
		End If
	Next
End Function
Private Function GetNewComponent(oAssDoc As AssemblyDocument, oNameFile As String) As Document
	For Each oRefDoc As Document In oAssDoc.AllReferencedDocuments
		If oRefDoc.FullDocumentName = oNameFile Then
			Return oRefDoc
		End If
	Next
	Return Nothing
End Function
I've tried moving the rule to close the active document up. Instead of putting it at the end.
This doesn't help which is weird because your message box shows the right filepath and right filename.
Let me know what you think.
BR
Justin
Message 6 of 12
Andrii_Humeniuk
Hi @J.VandeMerckt . You need to replace line 69:
asmDoc.Close(False)
On:
oAssDoc.Close(True)
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Message 7 of 12
J.VandeMerckt
Hi Andri
I thought the False line was to make sure the file doesn't get saved.
Or what is the difference between false and true.
BR
Justin
Message 8 of 12
Andrii_Humeniuk
SkipSave - True.
Message 9 of 12
J.VandeMerckt
Hi Andrii
Now it closes the file but I think I have other problems now.
The original file closes.
The new one opens but with this error:
In my new assembly the Part has the correct name but one it doesn't have the correct case selected. (the lenght did change correctly.
It seems like I will have to let the rule run completely and close the original file after.
Is it possible to have a snippet where I can specify the document it has to close? Or is this not the correct way to do this.
Message 10 of 12
Andrii_Humeniuk
I have made some changes, please change your code to the new one from the .txt document and try if it works.
Message 11 of 12
J.VandeMerckt
Hi
No still the same error.
Message 12 of 12
J.VandeMerckt
Is it maybe a idea to let the entire rule run and write another rule that executes after the first rule?
That way the first rule can run its course.
