Run part rule when changed from assembly
jaapschreuder
Message 1 of 1
jaapschreuder
I'm working on a 'smarter' design, where the influence of a constructor is more eliminated - to design in the same standard.
I'm having the part acting as I would, on part level - but unfortunately it doesn't get triggered on assembly level.
I cannot/will not run the rule for all occurrences because there could be really a lot, and it would be a real waste of time it is triggered a hundred times of more.
A small intruduction for my, I hope small issue;
is there someone who knows a workaround that this rule will be triggered?
(I'm aware that this will run the rule multiple times during constraining, but if it works with this rule - I will change the trigger for the rule to look if "all constraints" in assembly are active, and then run the rule)
Thanks in advance,
Jaap
Replies (0)
