iLogic idw to dwg fatal error
rsilvers
rsilvers
I've written this iLogic that will convert any open IDW to a DWG file.
Problem is when run this rule and have 15+ files open, it crashes half way thru.
Not sure why and I don't get any messages, just the Autodesk has crashed send in the report message.
Below is the code... anyone have any ideas?
Dim oDoc As Document
For Each oDoc In ThisApplication.Documents.VisibleDocuments
If oDoc Is Nothing Then
	MsgBox("Missing Inventor Document")
	Exit Sub
Try
	Dim ThisApp = ThisApplication
	Dim TransObj As TransientObjects = ThisApp.TransientObjects
	If oDoc.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
		MessageBox.Show("This Rule must be run from within a Drawing Document.", "Incorrect Document Type")
		Exit Sub
	Catch
	MessageBox.Show("Error Getting Document Information" & vbCr & "Is the current Document Saved?", "Document Error")
End Try
oFileName = System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName) 'without extension
'MessageBox.Show(oFileName, "Title")
oDoc.SaveAs(System.IO.Path.ChangeExtension(oDoc.FullFileName, ".dwg") , True)
'MessageBox.Show(oFileName & ".dwg  Saved!! " & vbCrLf & vbCrLf & ThisDoc.Path , "Save As")
oDoc.Activate
Next
ianteneth
Hi @rsilvers,
This rule works for me in Inventor 2020. I ran it on 33 empty (no views) IDWs and it made 33 empty DWGs. Maybe the issue is with exporting a particular drawing or views? Is it crashing on the same IDW everytime? Are you testing it on the same IDWs everytime?
On a side note I would surround the line where you actually export the IDW in a Try/Catch block or skip to the next IDW on error. Also, what are these lines for? They don't seem to be necessary.
