Run macro upon open
Run macro upon open
karthur1
Mentor Mentor
Run macro upon open
karthur1
Is there away to have Autodesk Inventor run a macro automatically everytime a file is opened?  I know that there are third-party apps out there that will do it, but I was trying to do it with the Autodesk Task Scheduler.
Sub AutoOpen()
<<your code>>
End Sub
This sub saved on the file should do the trick.
Same thing for
AutoNew()
AutoClose() and I think
AutoSave().
Regards.
ekinsb
I would recommend not using the automatic macros approach and would suggest an add-in instead.  You might want to read these two posts:
http://modthemachine.typepad.com/my_weblog/2008/09/vba-document-projects.html
http://modthemachine.typepad.com/my_weblog/2008/10/converting-vba-auto-macros-to-an-add-in.html
Brian Ekins
Mod the Machine blog
