Run iLogic rule with VB.NET Plug-in, Part 2
Daan_M
Daan_M
Hello again,
New post to keep things clean, I'm stuck on debugging my code. It stops at:
 Try
            iLogicAddin = _invApp.ApplicationAddIns.ItemById(iLogicAddinGuid)
            iLogicAutomation = iLogicAddin.Automation
        Catch
            MessageBox.Show("Unable to access iLogic addin")
        End Try
It shows the messagebox error
see below a screenshot and also the window that comes up with the 'Exception thrown' when i stop debugging my code. Any idea what causes this?
Code in insterted(in case its easier to read this way)
Private Sub RuleRunner()
        Dim MyRuleName As String = "cmdRead"
        Dim iLogicAddinGuid As String = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}"
        Dim iLogicAddin As ApplicationAddIn
        Dim iLogicAutomation As IiLogicAutomation = Nothing
        Try
        Catch
        End Try
        Try
            iLogicAutomation.RunRule(oDoc, MyRuleName)
        Catch
            MessageBox.Show("There is no rule called " & MyRuleName)
        End Try
    End Sub
Daan_M
i added;
Catch ex As Exception
MsgBox(ex.Message)
and it shows the following
LukeDavenport
Hi Daan,
Nearly there!
You need to use whatever reference you have to the Inventor application instead of _invApp in this line you currently have.
Where do you get that from? Well the Inventor application will probably be declared at the point that the addin is activated (normally this would be a sub called 'Activate' towards the top of your code) - it might be something like this in your code:
Dim InvApp As Inventor.Application = addInSiteObject.Application
So in the above case I could either pass the InvApp object to the sub that runs the iLogic rule, OR you could just create a global object for it (field or property of your class) so that you don't have to pass it to the sub.
Does that make sense?
Luke
jelte.de.jong
I did have the same problem when i started working with Automation properties of addins. The problem is that "iLogicAddin.Automation" always returns an object of the type "System.__ComObject". I never managed to cast it to something else like the type "IiLogicAutomation". but there is a solution just never cast it. That also means that you should not define the variable iLogicAutomation as the type IiLogicAutomation. try this code.
Dim iLogicAutomation As Object = Nothing ' As IiLogicAutomation = Nothing
Try
    MessageBox.Show("Unable to access iLogic addin " & ex.Message)
End Try
Try
Catch
End Try
Daan_M
@jelte.de.jong and @LukeDavenport
Thank you both so much, Jelte's tweak make the program work!
I'm really excited about this, i only discovered Inventor Automation with iLogic a month or two ago and i find it extremely intresting to see all the possibilities it offers.
Thanks again for the help on these forums, resources for beginners are scarsce, so feedback from experienced users is very valuable.
LukeDavenport
Thanks @jelte.de.jong.
I converted the code from C# to VB.net without checking it in an addin! That'll teach me.
Keep up the good work Daan.
Luke
