Run ilogic rule when Document is saved
Hello, friends.
I need this time that a(n) (external) rule runs when I save my document without the event triggers flagged.
I mean, when I save the "part" the rule runs.
NSBowser
Are you implying you need to run the rule WITHOUT using the built in iLogic Triggers? if so, is there a reason you cannot use the built in triggers? I have read a lot of stuff on getting the events (via api) but I do not believe they work through the iLogic interface).
Otherwise... use the built in iLogic triggers to run your rules on Before Save / After Save as appropriate.
Best of Luck!
Best of Luck
If you find this reply helpful or insightful, please use the 'Accept as Solution' or 'Kudos' button below.
