Run ilogic rule in each part from the assembly via external rule?
Message 1 of 21
I want to simply set a custom iproperty as the Description in each part file within my assembly.  I can do this easily at part level with ilogic but I want to be able to run the rule from the assembly level and all the parts run the rule.  I am struggling to find a way to do this.
I think this may be the best method I have found but I think it must be far easier?
http://inventortrenches.blogspot.com/search/label/Autodesk%20Inventor%20iLogic
Guy
Replies (20)
Message 21 of 21
Guido.LangeTuchscherer
@Anonymous
Hi there, I got the same issue, did you have any luck during the years?
I can't get the external rule to run.
