Run ilogic rule in assembly to set thickness of each parts
Neuzzo
Neuzzo
Hi all,
i need a rule in ilogic that when i run it in an assembly, that rule set a custom parameter called "SM_Style" with each part thickness.
Thickness parameter in italian version is called "Spessore"
Thank you all for your help.
Danilo "DannyGi" G.
Mechanical design engineer and product developer
Neuzzo
I've search and read about 28 pages of this forum, but no one can done this job.
Man Sad
Please help
Danilo "DannyGi" G.
smilinger
Why you need do that? Are you sure you want a custom parameter?
Because the thickness parameter is already there for sheetmetal parts, if you want a custom iproperty, why not just export the thickness parameter?
Neuzzo
Ok. Sorry for my noobish, but how can i set in a parts list a sheetmetal thickness?
I've not the thickness in my parts list
Danilo "DannyGi" G.
smilinger
In the parameters dialog, select parameter in the Export Parameter column, right click the parameter, set the format for the parameter, then save the file. You will see the parameter in your custom iProperty.
Neuzzo
Thank you. Really apreciated
Danilo "DannyGi" G.
