Run AutoCad Commands from iLogic
dalton98
dalton98
Hello. I'm not sure if this is possible, but I thought I'd ask...
I found an iLogic rule online that creates a dxf file from the flat pattern view.
https://clintbrown.co.uk/2020/09/05/ilogic-export-all-flat-patterns-to-one-dxf/
From there I have to open the newly created dxf file and delete/rename the layers assigned in order for our burn tables to read it. I wrote a simple script to fix the layers(merges layer IV_INTERIOR_PROFILE to layer 0)
-----------------------------------------------------fileType.scr
-LAYMRG
N
IV_INTERIOR_PROFILES
N
0
Y
Would it be possible to open the AutoCad file, run a script, and close it all in iLogic?
Much Appreciated,
Dalton Parrish
Michael.Navara
You can start AutoCAD program from iLogic
In arguments you can specify drawingFileName and you can use /b script file. Here is more info
Sample call from iLogic can looks like this
Dim acadExe = "C:\Program Files\Autodesk\AutoCAD 2020\acad.exe"
Dim dwgFile = "C:\Path\To\Drawing.dwg"
Dim scriptFile = "C:\Path\To\TestSrcipt.scr"
Dim args = dwgFile & " /b " & scriptFile
Process.Start(acadExe, args)
dalton98
@Michael.Navara
I couldn't get that solution to work
Process.Start(dwgFile) opens the desired file, but I still dont know how to automate running the scripts.
Also when I tried Process.Start(acadExe, args) it gives me an error
