rules to clean
rules to clean
rules to clean
is possible with a rule clean the view from : axes, planes, scketch, ......
JelteDeJong
I have been working on a rule but it got complicated fast. also i found a addin that can do that. In the idea station there is also a topic for a feature that does that. You might want to vote for it.
Jelte de Jong
Blog: hjalte.nl - github.com
_dscholtes_
We have some macros to switch the visibility of sketches, solid bodies, surface bodies, work planes / axis / points  on or off. They only work in parts thought. There has been no request for them to work on assemblies including sub assemblies. That might indeed get complicated as @JelteDeJong said.
Anyway, above mentioned items are all available through their individual collections in the ComponentDefinition of the active part (ComponentDefinition.Sketches, ComponentDefinition.WorkAxes, etc).
Edit: It seems you mean removing items, while I first interprated hiding them.
