hi @Anonymous worte an article about this on his site. Also i wrote an article about extra layers you can add to the export. (some software want that). check this.
Jelte de Jong
Blog: hjalte.nl - github.com
Dim oDoc As Inventor.PartDocument = ThisDoc.Document
Dim oPath As String = ThisDoc.Path
Dim oDef As Inventor.SheetMetalComponentDefinition = oDoc.ComponentDefinition
If oDef.FlatPattern Is Nothing Then
oDef.Unfold
Dim ModelDisplayName As String = oDoc.DisplayName
Dim YourPath As String = oPath & "\" & ModelDisplayName & ".dxf"
oDef.DataIO.WriteDataToFile("FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PROFILE", YourPath)
oDef.FlatPattern.ExitEdit
This will create dxf file with name of your sheetmetal file and in the same folder.
Would you be able to explain this code for me. I dont have any programming knowledge .
First of all this is an ilogic rule and should be run from part-sheetmetal file.
I added some comments:
'Declaring document
'Path of your sheetmetal file
'Definition of your component
'In case flat pattern does not exist yet - create one
oDef.Unfold
'filename of your sheetmetal file without path and extension
'Path and filename of new dxf file
'I assumed that the file will have the path and name like your sheetmetal file
'You can change it if you like
'Exporting do dxf
'back Folded Model in Inventor
Thanks Heaps. Lemme start with this.
