Rules for dimensions in Drawing
Hi all,
I started to use iLogic and create Rules in my projects recently. I'm using some Rules which suppress specific features depending on some parameters. However, whenever a feature is suppressed or reactivated, their respective dimensions lose their reference in the drawing. I wonder if I can create a Rule that would catch whether a feature is active or not in a drawing and, depending on that, suppress or reactivate dimensions.
Could someone explain how to go about this?
Thanks!
yan.gauthier
from my experience with VBA, when you loop through every dimensions/annotations in a drawing. if you encounter a dimensions refering to a supressed features, most of its property are in error state. If you try to access those properties, you will end up with errors too.
robertast
@Anonymous
I don’t know if you did something wrong. First I turn on all the functions and prepare the drawings, add all the dimensions. Later, if I suppress this feature, the dimensions will go out together with it. When activated, the dimensions will reappear.
And it doesn't depend on iLogic doing it or manually.
