How extract area and an arc length from a region construct by a sketch
moraesorlando
moraesorlando
Hello colleagues!
I am here again to ask for help.
I have already got good answers about how extract values from solid bodies and put these values in fields within a form from this forum and I am grateful for that.
Now I have a similar situation but the values to be extract does not come from a solid but from a region created in a sketch.
Below are the steps about how I wonder this is going to work:
After load the form.
The user clicks in a button and select an arc from a region created by sketch. The value of the arc length is shown in the respective field in the form.
Then The user clicks in a second button and select an internal area from any region existent in the sketch and the value of internal area is shown in the respective field in the form.
I have prepared the form, the parameters, the buttons but I don’t know how to create the ilogic code.
And I would like to count with the colleagues to help to accomplish this target.
I have prepared an image to help to transmit my idea.
I am also attaching the file with all the preparations to receive the code.
I am using Inventor version 2020 and I am available to supply any other necessary information.
Thanks in advance for every one that can help.
Best regards,
JhoelForshav
@moraesorlando
I've filled in the rules in your attached ipt 🙂
I hope it's what you are looking for.
See attached ipt.
moraesorlando
Hello @JhoelForshav
Congratulations! You always are solving the cases, thank you very much!
I have placed these rules in my real situation and works correctly!
That’s exactly what I am looking for.
Just an additional question.
How can I do to control the number of decimal places of in area and length results?
For example, in the region identified with “Internal area”:
Is possible to get the number 2002.xxxxxxxxxxx for area result.
How to control the decimal places to get 2002.243 or 2002,24282?
Thanks in advance.
Best regards,
JhoelForshav
Hi @moraesorlando
See attached ipt. I've added a parameter to the part where you can set the number of decimal places you want to use and updated the code accordingly 🙂
moraesorlando
Hello @JhoelForshav after a long time I got back to this pursuit
I was engaged in other Inventor pursuits (sorry about this long time to get back to finish this post).
I have tried to use the example in the file you sent to set the quantity of decimal places, but after a while trying to solve without succeeded I have identified the reason.
In your example to extract the value from area, you have used a parameter from type TEXT and in my real situation I have used a parameter FROM TYPE “Numeric”.
I think, because of this I could not set the decimal places adapting your code to my case.
The adapted code I am trying to use is:
Parameter.Param("High_Profile_Area").Value = Math.Round((oProfile.RegionProperties.Area * 10), 5, MidpointRounding.AwayFromZero)
Using numbers for better understanding:
The result of this code in my test is 98277,17290000
The results show 8 decimals places instead of 5
The expected value is 98277,17290
I believe the code I have adapted to set the decimal places shown above is not correct to a parameter type "numeric".
I appreciate your help.
Thanks in advance and best regards,
JhoelForshav
You should use .Expression instead of .Value then @moraesorlando
I have two options for you. Both should work... See which one you like best.
You could do it like this:
Parameter.Param("Area_from_sketch").Expression = Math.Round((oProfile.RegionProperties.Area * 10), 5, MidpointRounding.AwayFromZero).ToString
Or like this:
Parameter.Param("Area_from_sketch").Expression = (oProfile.RegionProperties.Area * 10).ToString("0.00000")
moraesorlando
Hello @JhoelForshav !
Thanks for your quick reply.
I have used the first example and everything worked as expected.
Thank you very much, you are very good on that.
One more case solved!
I will mark this post as accepted solution.
See you in the next Inventor pursuits.
Best regards,
