Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
rule to auto update and save drawing to pdf
mitoborecek
Message 1 of 33
mitoborecek
How to make/run rule in drawing .dwg after change all parapeters and autoremodel assemble .iam.
When run rule in drawing I need tu update drawing (take about 10-15 sec) and save as .pdf with name (some parameter in assemble)
Replies (32)
Message 21 of 33
mitoborecek
It sounds good, but I change only one parameter in assembly using Forms - it changes everything I need (import sizes and setting from excel)
Message 22 of 33
lewiskam723
Observer
Observer
To auto-update and save a drawing to PDF after changing parameters and remodeling an assembly in Autodesk Inventor, create an iLogic rule. The rule should first update the .dwg file after the assembly (.iam) changes, then introduce a delay (10-15 seconds) to complete the update process. Finally, it saves the drawing as a PDF, naming the file using an assembly parameter.
Message 23 of 33
mitoborecek
I need change only one parameter evrey time in assembly, and after finish all changes what made this one parameter, need run rule in drawing (update + export to pdf)
Message 24 of 33
J-Camper
@mitoborecek,
You said you change the parameter with a form right?  You can create a button on the form that calls the rule.  That way you shouldn't have to close the form.
If you don't like that then try one of the options, to incorporate calling the second rule at the end of your assembly adjustment rule, that I mentioned previously.
Message 25 of 33
mitoborecek
This is good idea, I will try it
but sometime I have parameter with simbol - for example "/" and export to pdf ended with error.
How to edit code, to end with open window "save as", where I write name of pdf?
Message 26 of 33
J-Camper
If you don't want to manually edit the name, you can remove any invalid characters from the Name Parameter before adding to the filename:
Function GetPDFFileName(dDoc As DrawingDocument) As String
	Dim FileName As String = System.IO.Path.GetDirectoryName(dDoc.FullFileName) & "\"
	Dim IssueIndex As String = "Missing Reference Assembly"
	If dDoc.ReferencedDocuments.Count > 0
		Dim aDoc As AssemblyDocument = TryCast(dDoc.ReferencedDocuments.Item(1), AssemblyDocument)
		If aDoc IsNot Nothing
			Try
				IssueIndex = aDoc.ComponentDefinition.Parameters.Item("Name").Value.ToString
			Catch
				IssueIndex = "Missing_Name_Parameter"
			End Try
		End If
	End If
    For Each c As Char In System.IO.Path.GetInvalidFileNameChars()
      IssueIndex = IssueIndex.Replace(c.ToString, "")
    Next
	If IssueIndex = String.Empty Then IssueIndex = "Trimmed_Full_Name_Parameter_Value"
	FileName = String.Format("{0}{1}{2}", FileName, IssueIndex, ".pdf").ToString
	Return FileName
End Function
Added lines 22-26 to the previous function post
Message 27 of 33
mitoborecek
This works perfect.
One last thing. Is there rule after save to pdf to change parameter in assembly . The parameter is text - list of names. Names are Allways different. Need to automating this all.
Message 28 of 33
J-Camper
I added a Sub call in the filename function:
	Dim aDoc As AssemblyDocument = Nothing
		aDoc = TryCast(dDoc.ReferencedDocuments.Item(1), AssemblyDocument)
			Try
			Catch
			End Try
		End If
	End If
    Next
	If aDoc IsNot Nothing Then LogNameInNames(aDoc, IssueIndex)
	Return FileName
End Function
Sub LogNameInNames(aDoc As AssemblyDocument, NameToAdd As String)
	Dim ListParam As Inventor.Parameter
	Try
		ListParam = aDoc.ComponentDefinition.Parameters.Item("Names")
	Catch
		ListParam = aDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("Names", NameToAdd, UnitsTypeEnum.kTextUnits)
	End Try
	Dim CurrentList As IList = MultiValue.List(aDoc.DisplayName, "Names")
	If Not CurrentList.Contains(NameToAdd) Then CurrentList.Add(NameToAdd)
	MultiValue.List(aDoc.DisplayName, "Names") = CurrentList
End Sub
Change "Names" to whatever your list parameter name is.
Message 29 of 33
mitoborecek
parameter name didn´t change.
Message 30 of 33
J-Camper
It should adding an entry to the list parameter.  Did you want the list parameter's value to be the newest entry in the list?
Message 31 of 33
mitoborecek
I have list parameters imported from excel. I need to auto change this parameter from 1. To last value. And after change value from 1. To 2. Value - update drawing and export to pdf
Message 32 of 33
J-Camper
I thought you already had a rule doing the assembly changes based on the excel file.  I feel like I'm not fully understanding the request.  Can you elaborate or post images/examples of what you are trying to automate?
Feel free to correct me if I'm wrong, but this feels like it is deviating from the initial forum post, and would benefit from a separate post.  If you do make a new post you can @ me to make sure I see it.
Message 33 of 33
mitoborecek
You are right. I made new post
Thank you very much
