Rule not working as an External Rule
donaldleigh
Message 1 of 10
donaldleigh
Hi all
I have 3 custom iProperties, Job No. & Line No.Sheet No.
If Sheet No. has 2 digits then Part Number iProperty will equal "Job No.-Line No.-Sheet No.
but if Sheet No. has 1 or 3 and more digits then Part Number iProperty will equal only the Sheet No.
Now. I have the below code that work only if the rule is in the part. if I add this to the external rules all I get is the small thinking windows circle and then I have to close Inventor.
The rule will be set to trigger with iProperty change.
Can someone please let me know what I'm missing
Donald
Inventor 2014 (Soon to be 2019)
SyntaxEditor Code Snippet
EJN = iProperties.Value("Custom", "Job No.")
ELN = iProperties.Value("Custom", "Line No.")
ESN = iProperties.Value("Custom", "Sheet No.")
SNL = Len(ESN)
If SNL = 1 Then
    iProperties.Value("Project", "Part Number") = iProperties.Value("Custom", "Sheet No.")
Else If SNL = 2 Then
    iProperties.Value("Project", "Part Number") = EJN & "-" & ELN & "-" & ESN
Else If SNL > 2 Then
End If
iLogicVb.UpdateWhenDone = True
Replies (9)
Message 2 of 10
bshbsh
I'm guessing a rule that changes iproperties and triggered on iproperty change would cause an infinite loop, probably that's what you are seeing.
Message 3 of 10
chandra.shekar.g
Autodesk Support
Autodesk Support
@donaldleigh,
Actually, posted iLogic code is tested in Inventor 2019 and it is working fine.
Hoping that below iLogic code might help in Inventor 2014. Guessing that, referenced document is missing while running as external rule.
Dim oDoc As Document
oDoc = ThisDoc.Document
EJN = oDoc.PropertySets.Item(4).Item("Job No.").Value
ELN = oDoc.PropertySets.Item(4).Item("Line No.").Value
ESN = oDoc.PropertySets.Item(4).Item("Sheet No.").Value
SNL = Len(ESN)
If SNL = 1 Then
	oDoc.PropertySets.Item(3).Item("Part Number").Value = oDoc.PropertySets.Item(4).Item("Sheet No.").Value
	oDoc.PropertySets.Item(3).Item("Part Number").Value = EJN & "-" & ELN & "-" & ESN
Else If SNL >2 Then
End If
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 4 of 10
donaldleigh
hi @bshbsh
That makes sense. but why would it do that as an external rule but not when the rule is in the part?
is there a way to stop the loop runing?
Message 5 of 10
donaldleigh
that didn't work
if it works in 2019 as you say maybe ill wait on this till we upgrade. this should be soon I'm told
Message 6 of 10
donaldleigh
@chandra.shekar.g
I have the rule working now as an external rule but when I set the event trigger to run on iProperty change that's when I have the crash. As @bshbsh suggested it must be looping though and not stopping.
I have had a similar rule work this way.
Message 7 of 10
chandra.shekar.g
Autodesk Support
Autodesk Support
@donaldleigh,
Nice to hear that iLogic rule is working.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 8 of 10
donaldleigh
The rule is working thanks but
If I set the event trigger to "iProperty Change" with the external rule inventor chases.
but with set to the same rule but as an internal rule it all works fine
Any idea why this happens
Message 9 of 10
bshbsh
Generally, you have very bad control over a lot of things with ilogic. For example, there is no easy way (that i know of) to disable and re-enable event triggers programamtically when you need to. There might be tricks to circumvent some of these flaws, but I'm not really into ilogic anymore.
However, in this case, a little good practice may help. Basically, you want to craft what your new iproperty value would have to be as a variable first (and NOT directly into the iproperty itself!), then compare this with the actual value of that iproperty, and only change it when they are different. I assume this would prevent the iprop change event firing unnecessarily causing the loop. Also, it would not make your file dirty and requiring save unnecessarily.
So something like this:
SNL = Len(ESN)
Dim NewPN as String
If SNL = 2 Then
    NewPN = EJN & "-" & ELN & "-" & ESN
Else
    NewPN = ESN
End If
If iProperties.Value("Project", "Part Number") <> NewPN then
    iProperties.Value("Project", "Part Number") = NewPN
End if
Message 10 of 10
donaldleigh
@bshbsh
your are a genius.
That worked. I will keep testing it but thanks. Owe you a drink.
Donald
