Rule in drawing: To retrieve custom properties of a non-model drawing
RoyWickrama_RWEI
Advisor Advisor
RoyWickrama_RWEI
Rule in drawing document: Using the following
oModelDoc = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
I retrieve model document properties in to the drawing document and vice versa.
Recently, with the same rule running in drawing, I also need to retrieve such data from a part or assembly of a non-model-document.
Path and file name of this other document is known. Please see below! Can I retrieve the description (for example) of this other document. I tried my best without success. Request help. Thank you.
Sub Main()
	oDoc = ThisDrawing.ModelDocument
	Dim invCustomProps As Inventor.PropertySet
	invCustomProps = oDoc.PropertySets.Item("User Defined Properties")
	Dim invCustomProp As Inventor.Property
Description_Model = iProperties.Value(oModelDoc, "Project", "Description")
MessageBox.Show("Model_Desn: " & Description_Model, "Title")
oDoc_Other = "C:\$WF_DHAMAG\Projects\DHAMAG_SDAI\ADSI-P001-ARF33\P001-A0001.iam"
Description_Other = ?????????????????
End Sub
Drawing (for Example): C:\$WF_DHAMAG\Projects\DHAMAG_SDAI\ADSI-P001-ARF33\P001-A0001.iam
Model Document (for example): C:\$WF_DHAMAG\Projects\DHAMAG_SDAI\ADSI-P001-ARF33\P001-sa1001.idw
Other Document (Example): C:\$WF_DHAMAG\Projects\DHAMAG_SDAI\ADSI-P001-ARF33\P001-A0001.iam
RoyWickrama_RWEI
Sub Main()
End Sub
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI,
Try below code to get iProperties of non model document.
oDoc_Other = C:\$WF_DHAMAG\Projects\DHAMAG_SDAI\ADSI-P001-ARF33\P001-A0001.iam
Dim oDoc As Document oDoc = ThisApplication.Documents.Open(oDoc_Other, False) Dim oDescription As String oDescription = oDoc.PropertySets.Item("Design Tracking Properties").Item("Description").Value MessageBox.Show(oDescription, "Title")
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
RoyWickrama_RWEI
Thanks a lot, Sir.
It does exactly what I need currently.
