Rule/Add-in to automatically slice graphics on sketch creation/edit
Pretty much the title.
I want to create an iLogic rule or vb.net add-in that will automatically run the command "Slice Graphics" when a sketch in the part/assm environment is created.
I've got about 50hrs experience with programming, but I need assistance with where to start.
Any pointers would be appreciated!
Sergio.D.Suárez
Hello, try to execute these two lines as an ilogic rule.
ThisApplication.CommandManager.ControlDefinitions.Item("PartNewSketchCmd").Execute2(True)
ThisApplication.CommandManager.ControlDefinitions.Item("SketchSliceGraphicsCmd").Execute2(True)
 I hope this helps. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
@Sergio.D.Suárez
Almost perfect!
Since I've never done it before and don't know what it's called, I don't get meaningful results when I try to search. Is it possible to have:
run anytime a sketch is edited or created new? I see some kind of for/while loop that waits for NewSketch or EditSketch, then runs and restarts the rule. Could you provide any insight to how to get an iLogic rule to wait for a command to be run?
It looks like the solution will involve writing an Addin. As I'm a complete noob in that arena, it will be a few days/weeks before I have it finished. I will update here with the code once completed.
Maxim-CADman77
Just in case: recently I've added the function desired in 1.0.2 version of my tiny little Add-In that automates activation of some popular 3D-model view modes.
I suggest to try if it suit your needs - SmartProjectEm.msi
Please vote for Inventor-Idea Text Search within Option Names
