Row visibility
Row visibility
Row visibility
The API doesn't appear to provide the ability to turn visibility off on a custom table row. Is there anyway to turn off the visibility of a row?
Autodesk: do you have plans on adding this functionality to the API?
Nate
This capability was added to the API in Inventor 2009. The Row.Visible
property provides this.
Sanjay-
Awesome Thanks for the quick responses. Now I just need to get my IS Team to install the new version. We are still on 2008.
Ktelang
Please help me, I am using 2012
I have a ipart linked customtable inserted
in a drawing using general table command in
Drawing environment.
Dim OrDoc As DrawingDocument, OrDocSheet As Sheet
Set OrDoc = ThisApplication.ActiveDocument
Set OrDocSheet = OrDoc.Sheets("Sheet:1")
Dim Table As CustomTable
Set Table = OrDocSheet.CustomTables.Item(1)
Dim oRow As Row
Set oRow = Table.Rows.Item(3)
oRow.Visible  '... is this sytanx correct, as its giving me some compile error "Invalid use of property"
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
Ktelang
Never mind it was syntax
Table.Rows(1).Visible = False
Table.Rows(3).Visible = True
