Rotate Appearance on a face by 90 degrees
hozz__
hozz__
I found this code example that is supposed to handle rotating an  appearance override  image by 90 degrees, but I experience 2 problems with it...
1. There is no asset of type "kAssetValueTextureType"
2. An Asset value of type kAssetValueTypeColor" exists, but it has no connected texture
As a result the code fails to run as expected...it's a material and image from a custom material library if that helps.
How else might I need to access the asset properties in order to rotate it? Or is there something else missing in my code?
Sub RotateTextureOfAppearanceOnFace(oFace As Face)
	oWrite.WriteLine(vbTab & vbTab & Now & "RotateTextureOfAppearanceOnFace(oFace As Face)")
    Dim oAppearance As Asset
    oAppearance = oFace.Appearance
    Dim oNewAppearance As Asset
    oNewAppearance = oAppearance.Duplicate
    Dim oAssetValue As AssetValue
    Dim oValue As AssetValue
    Dim oTextureAssetValue As TextureAssetValue
    Dim oRotationValue As FloatAssetValue
    Dim oAssetTexture As AssetTexture
	 Dim oColorAssetValue As TextureColorValue
    ' find a texture and rotate the texture by 90 degrees.
    For Each oAssetValue In oNewAppearance
		If oAssetValue.ValueType = kAssetValueTextureType Then
            If InStr(1, LCase(oAssetValue.Name), "color") Then
                oTextureAssetValue = oAssetValue
  				oRotationValue = oTextureAssetValue.Value("texture_WAngle") '(23) / Angle
                oRotationValue.Value = 0 '90 ' This should be a defect that the Double value is not in radians.
            End If
         ElseIf oAssetValue.ValueType = kAssetValueTypeColor Then
            Dim oColorAssetValue As ColorAssetValue
            oColorAssetValue = oAssetValue
            If oColorAssetValue.HasConnectedTexture Then
                MsgBox("ColorAssetValue: " & oAssetValue.Name)
                    oAssetTexture = oColorAssetValue.ConnectedTexture
                    oRotationValue = oAssetTexture.Item("texture_WAngle") '(23) / Angle
                    oRotationValue.Value = 90 ' This should be a defect that the Double value is not in radians.
            End If
        End If
    Next
    ' override the appearance
    oFace.Appearance = oNewAppearance
End Sub
Any help is greatly appreciated
chandra.shekar.g
Autodesk Support
Autodesk Support
@hozz__ ,
Hoping that suggestions in the below link may be helpful.
https://adndevblog.typepad.com/manufacturing/2015/11/texture-rotation-in-the-inventor-api.html
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
