Ribbon Tab bug
Ribbon Tab bug
gustavo.cassel
Ribbon Tab bug
gustavo.cassel
Hi, i'm having an issue with the ribbon tab.
When i execute this code from an assembly, to unfold all sheetmetal parts, the main assembly ribbon tab turns in a sheetmetal ribbon tab.
Sub createFlatPattern(doc As PartDocument)
    Dim metaldef As SheetMetalComponentDefinition
    Set metaldef = doc.ComponentDefinition
    If Not metaldef.HasFlatPattern Then
        metaldef.Unfold
        metaldef.FlatPattern.ExitEdit
    End If
End Sub
As you can see, i'm currently in a assembly document and the sheetmetal ribbon tab is active.
I want a way to fix it, please.
Curtis_Waguespack
Hi @gustavo.cassel
See this link to a past discussion/solution to this issue:
https://forums.autodesk.com/t5/inventor-forum/toolbar-switching-to-sheet-metal-part-when-ilogic-rule...
I hope this helps.
Curtis
gustavo.cassel
Hello @Curtis_Waguespack
The method that you show me its to add a view to the part to make it visible and then unfold it. I can't use this method because I have a lot of OnOpenDocument events and it pop-ups message boxes. Making the code to unfold all parts freezes until someone close the messagebox.
I found a way to "refresh" the ribbon when the code finish.
AssemblyDocument assemblyDocument = (AssemblyDocument)invApp.ActiveDocument;
invApp.CommandManager.ControlDefinitions["AppShowHomeBaseCmd"].Execute2(true); // ( HomeBaseView )
assemblyDocument.Activate();
When the code ends, it change to the HomeBaseView and back to the assembly.
Anyway, thanks @Curtis_Waguespack for the help!
