Revision Table iProperties
GSK2019
GSK2019
I am currently trying to make an automatic revision table, when you use the rule, it will update the letter in the revision block as well as on the sheet. But So far i am running against some problems with the revision table:
- And it is not updating the iProperty's Revision Number
Sub Main()
	Dim Odoc As Document = ThisDoc.Document
	Dim DrawDoc As DrawingDocument = ThisApplication.ActiveDocument
	Dim oSheet As Sheet
	Dim visibleRowsWanted As Integer = 3
	For Each oSheet In DrawDoc.Sheets
		If oSheet.RevisionTables.Count = 0 Then
			Call AddRevTable(DrawDoc)
			Else
				Call AddRevRow(DrawDoc)
				Call PurgeRev(DrawDoc, visibleRowsWanted)
	Next
InventorVb.DocumentUpdate()
End Sub
Sub AddRevTable(DrawDoc As DrawingDocument)
'    Dim oDrawDoc As DrawingDocument
'    oDrawDoc = ThisApplication.ActiveDocument
    Dim oRTBs As RevisionTables
    oRTBs = DrawDoc.ActiveSheet.RevisionTables
    Dim oLocation As Point2d
    oLocation = ThisApplication.TransientGeometry.CreatePoint2d(10, 10)
    'add a new table
    Dim oRTB As RevisionTable
    oRTB = oRTBs.Add2(oLocation, True, True, True, "A")
	iProperties.Value("Project", "Revision Number") = "A"
End Sub
Sub AddRevRow(DrawDoc As DrawingDocument)
'	Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
' Get the revision table
Dim oRevTable As RevisionTable = DrawDoc.ActiveSheet.RevisionTables.Item(1)
' Get last row
Dim oRow As RevisionTableRow
oRow = oRevTable.RevisionTableRows.Item(oRevTable.RevisionTableRows.Count)
' Make sure we have the active row
If oRow.IsActiveRow Then
' Go through all columns in that row
For i = 1 To oRevTable.RevisionTableColumns.Count
Dim oCell As RevisionTableCell = oRow.Item(i)
' Set all cells to static
oCell.Text = oCell.Text
' or static and blank'oCell.Text = ""
Next
' Add another row at the end
Dim oRows As RevisionTableRows = oRevTable.RevisionTableRows
oRows.Add()
End Sub
Sub PurgeRev(DrawDoc As DrawingDocument, visibleRowsWanted As Integer)
	For Each sheet As Sheet In ThisDrawing.Document.Sheets
  		For Each revTable As RevisionTable In Sheet.RevisionTables
    		Trace.WriteLine(" --- " & revTable.Title)
			Dim rows As RevisionTableRows = revTable.RevisionTableRows
			Dim numberToHide As Integer = rows.Count - visibleRowsWanted
	If (numberToHide <= 0) Then Continue For
	For i = 1 To numberToHide
	  rows(i).Visible = False
	Next
  Next
Next
 End Sub
So far I have this, how can i make sure it also updates the iProperties?
A.Acheson
Here is the snippet you need from the API help
Syntax
RevisionTable.UpdatePropertyToRevisionNumber() As Boolean
Regards
Alan
GSK2019
How would you incorporate this in the code?
Because when I try it in my code I get the following Error:
Sub Main()
	Dim oSheet As Sheet
			Else
	Next
End Sub
    'add a new table
'	iProperties.Value("Project", "Revision Number") = "A"
End Sub
' Get last row
Next
oRows.Add()
oRevTable.UpdatePropertyToRevisionNumber(True)
End Sub
	Next
  Next
Next
 End Sub
A.Acheson
Maybe try
oRevTable.UpdatePropertyToRevisionNumber = True
In the error message it looks like it isn't reading the boolean assignment as you have written it.
Regards
Alan
GSK2019
It didn't work. It only reads True or False. I now have a MsgBox before it, and when i have
It reads False and vise versa.
Nothing else happens
A.Acheson
The reason your not seeing an update to the drawing revision is because the table is set up for sheet scope and not drawing scope.. The below adds a table with drawing scope meaning every revision table will update with the same revision.
   oRTB = oRTBs.Add2(oLocation, False, True, True, "A")
	oRTB.UpdatePropertyToRevisionNumber = True
I see there is more than one table is added so the detection of a table is likely not working correctly.
Regards
Alan
GSK2019
Awesome! This works thank you so much!
