Feature is active with letter
jostroopers
jostroopers
I have an excel sheet which is linked to my model.
In one of the columns it says 'Opties'.
This is a combination of letters.
This can be multiple letter combinations linked to a feature.
Now I have processed each option into a case.
However, is it possible in iLogic to search in the letter code which letter is present and then turn the feature on and/or off, False or True.
Example:
F = vast , then all options are off.(false)
Hijsconstr = h
Zonwering = b
Regensensor = r
Windsensor = w
Inbraak = i
Kabel zonwering = k
I now have several opties: F, Fh, Fhi, Fhik, Fhikbrw, Fkbrw
and 30 combinations more.
Current code:
Select Case Opties
	Case "F"
		Feature.IsActive("13360-01", "Hijsconstr") = False
		Feature.IsActive("13360-02", "Hijsconstr") = False
		Feature.IsActive("13360-03", "Zonwering") = False
		Feature.IsActive("13360-04", "Zonwering") = False
		Feature.IsActive("13360-02", "Regensensor") = False
		Feature.IsActive("14560-01", "InbraakEind") = False
		Feature.IsActive("14560-01", "InbraakLi") = False
		Feature.IsActive("14560-01", "InbraakRe") = False
		Feature.IsActive("14560-01", "InbraakKop") = False
		Feature.IsActive("14560-02", "InbraakEind") = False
		Feature.IsActive("14560-02", "InbraakLi") = False
		Feature.IsActive("14560-02", "InbraakRe") = False
		Feature.IsActive("14560-02", "InbraakKop") = False
		Feature.IsActive("14560-03", "InbraakLi") = False
		Feature.IsActive("14560-03", "InbraakRe") = False
		Feature.IsActive("14560-04", "InbraakLi") = False
		Feature.IsActive("14560-04", "InbraakRe") = False
		Feature.IsActive("14561-04", "KabelZonwering") = False
		Feature.IsActive("13362-04", "KabelZonwering") = False
Case "Fkbrw"
		Feature.IsActive("13360-03", "Zonwering") = True
		Feature.IsActive("13360-04", "Zonwering") = True
		Feature.IsActive("13360-02", "Regensensor") = True
		Feature.IsActive("14561-04", "KabelZonwering") = True
		Feature.IsActive("13362-04", "KabelZonwering") = True
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
JelteDeJong
You could try something like this:
Dim inputString = "Fhik"
'I use inputString.ToUpper() to make sure I always compare with capital letters.
If inputString.ToUpper().Contains("F") Then
    MsgBox("String contains F")
    ' set your features
    'Feature.IsActive("13360-01", "Hijsconstr") = False
    'Feature.IsActive("13360-02", "Hijsconstr") = False
    'Feature.IsActive("13360-03", "Zonwering") = False
    'Feature.IsActive("13360-04", "Zonwering") = False
    'Feature.IsActive("13360-02", "Regensensor") = False
    'Feature.IsActive("14560-01", "InbraakEind") = False
    'Feature.IsActive("14560-01", "InbraakLi") = False
    'Feature.IsActive("14560-01", "InbraakRe") = False
    'Feature.IsActive("14560-01", "InbraakKop") = False
    'Feature.IsActive("14560-02", "InbraakEind") = False
    'Feature.IsActive("14560-02", "InbraakLi") = False
    'Feature.IsActive("14560-02", "InbraakRe") = False
    'Feature.IsActive("14560-02", "InbraakKop") = False
    'Feature.IsActive("14560-03", "InbraakLi") = False
    'Feature.IsActive("14560-03", "InbraakRe") = False
    'Feature.IsActive("14560-04", "InbraakLi") = False
    'Feature.IsActive("14560-04", "InbraakRe") = False
    'Feature.IsActive("14561-04", "KabelZonwering") = False
    'Feature.IsActive("13362-04", "KabelZonwering") = False
If inputString.ToUpper().Contains("H") Then
    MsgBox("String contains H")
    ' set your features for Hijsconstr
If inputString.ToUpper().Contains("R") Then
    MsgBox("String contains R")
Jelte de Jong
Blog: hjalte.nl - github.com
jostroopers
@JelteDeJong
Thanks for your response.
However this is not what I mean.
I have a parameter 'Opties' which is filled from excel.
Now that letter combination should be placed in the rule.
Then the code should check which letters are present and set the corresponding feature to True.
If the letter is not present the feature should remain or be set to Falls.
And the msgbox is not what i want because i have to click it everytime a letter is present.
Mvg Jos
JelteDeJong
If there is no code needed for filling the "Opties" (I have a parameter 'Opties' which is filled from excel.) then you can just use it in the rule. like this:
Dim inputString = Opties
    ' set your features
Jelte de Jong
