Retrieve model dimensions with tolerances
abhay.gilka
Message 1 of 9
abhay.gilka
Is it possible to retrieve only those model dimensions in inventor drawing for features that has tolerance specified in model sketch. Inventor brings all dimensions which are not useful.
Replies (8)
Message 2 of 9
Viktor.Lukjanow
I need that too, is there a possibility?
Message 3 of 9
ryan.rittenhouse
This is pretty quick and dirty, but it should get the job done for you:
Dim currentDoc As DrawingDocument = ThisDrawing.Document
Dim currentSheet As Sheet = currentDoc.ActiveSheet
For Each drawView As DrawingView In currentSheet.DrawingViews
	Try
		currentSheet.DrawingDimensions.GeneralDimensions.Retrieve(drawView)
	Catch
		Logger.Error("Error auto dimensioning " & drawView.Name)
	End Try
Next drawView
For Each genDim As GeneralDimension In currentSheet.DrawingDimensions.GeneralDimensions
	If genDim.Tolerance.ToleranceType = kDefaultTolerance Then genDim.Delete
Next genDim
Let me know if it works for you.
If this solved your problem, or answered your question, please click Accept Solution.
Message 4 of 9
WCrihfield
Yep, the DrawingView.Include3DAnnotations property is just a Read/Write Boolean, so it does not offer a custom way to filter which ones it will include.  You may just have to include all of them at first, then iterate through them afterwards with your code, and delete the ones you don't want, based on their tolerance settings.
Wesley Crihfield
(Not an Autodesk Employee)
Message 5 of 9
Viktor.Lukjanow
Really great. Thank you very much. Can you extend it a bit so that when I run the iLogic I can select the view first and then only that view should run that iLogic.
Message 6 of 9
Viktor.Lukjanow
Hi @ryan.rittenhouse,
I've adapted the code so that I have to select the view first and this function doesn't go through all the views. that's how it works. Would you do it differently? or like this?
' Überprüfen, ob eine Ansicht ausgewählt ist
Dim selectedObjects As SelectSet = ThisApplication.ActiveDocument.SelectSet
If selectedObjects.Count = 0 Then
	MessageBox.Show("Keine Ansicht ausgewählt. Bitte wählen Sie eine Ansicht aus.", "Hinweis")
	Return
End If
For Each selectedObj In selectedObjects
	If TypeOf selectedObj Is DrawingView Then
		Dim drawView As DrawingView = selectedObj
		Try
		Catch
			Logger.Error("Fehler beim automatischen Bemaßen von " & drawView.Name)
		End Try
		' Löschen von Standardtoleranzmaßen
		For Each genDim As GeneralDimension In drawView.Parent.DrawingDimensions.GeneralDimensions
		Next genDim
	Else
		MessageBox.Show("Bitte wählen Sie eine Zeichnungsansicht aus.", "Hinweis")
	End If
Next
Message 7 of 9
ryan.rittenhouse
That looks good. Most importantly, if it's working for you, go with it.
Message 8 of 9
Viktor.Lukjanow
THX @ryan.rittenhouse
Your code was a great help to me.
Message 9 of 9
Viktor.Lukjanow
for all others who also need this code. this one works better. here really only retrieved measures and without tolerance are deleted.
    Return
End If
        drawView.Include3DAnnotations = True ' Sicherstellen, dass 3D-Anmerkungen berücksichtigt werden
        Try
            ' Abrufen der Modellbemaßungen
            ThisApplication.CommandManager.ControlDefinitions.Item("DrawingSelectAllModelDimsCmd").Execute
        Catch ex As Exception
            Logger.Error("Fehler beim automatischen Bemaßen von " & drawView.Name & ": " & ex.Message)
        End Try
        ' Erstellen einer Liste aller ausgewählten Modellbemaßungen
        Dim selectedDims As New List(Of GeneralDimension)
        For Each selectedItem In ThisApplication.ActiveDocument.SelectSet
            If TypeOf selectedItem Is GeneralDimension Then
                selectedDims.Add(CType(selectedItem, GeneralDimension))
            End If
        Next
        ' Löschen aller ausgewählten Modellbemaßungen ohne Toleranz
        For Each genDim As GeneralDimension In selectedDims
            If genDim.Tolerance Is Nothing OrElse genDim.Tolerance.ToleranceType = kDefaultTolerance Then
                Try
                    genDim.Delete()
                    Logger.Error("Fehler beim Löschen der Bemaßung: " & ex.Message)
                End Try
            End If
        Next
    Else
    End If
Next
