Retrieve iMate Name
Retrieve iMate Name
RajivAngoelal
Retrieve iMate Name
RajivAngoelal
Hello Guys,
I want to write a code that retrieves the names of the iMates that has been set in a constraint.
am using j2 parts called RHS_O and RHS_1.
The following is a constraint called SC and the "Bottom" and "Left" are iMates between the parts.
Constraints.AddByiMates("SC", "RHS_0:1", "Bottom", "RHS_1:1", "Left")
Now i would like to retrieve the iMates names in a string.
Help is much appreciated :).
WCrihfield
Would this do what you are wanting done?
Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
Dim oConstraints As AssemblyConstraints = oADef.Constraints
Dim oIMName As String = oConstraints.Item("SC").iMateResult.Name
Wesley Crihfield
(Not an Autodesk Employee)
RajivAngoelal
Dear WCrihfield,
I will test it and get back to you.
Thank you for your effort 🙂
WCrihfield
I think I may have a better solution for you.  I have not tried it out yet, so let me know if this does what you need.
Dim oConst As AssemblyConstraint
For Each oConst In oConstraints
	If oConst.Name = "SC" Then
		If oConst.ResultOfiMate = True Then
			Dim oiMateDef1 As iMateDefinition
			Dim oEntity1 As iMateDefinition
			oConst.iMateResult.GetInputs(oiMateDef1, oEntity1)
			MessageBox.Show("Constraint Name: " & oConst.Name & vbNewLine &
			"First iMate Name = " & oiMateDef1.Name & vbNewLine &
			"Second Entity Name = " & oEntity1.Name)
		End If
	End If
Next
Wesley Crihfield
RajivAngoelal
Sorry for my late reaction, i have a fever.
It works like a charm.
Thank you 😄
