Retrieve dimension very slow
johnster100
johnster100
i'm using the code:
oSheet.DrawingDimensions.GeneralDimensions.Retrieve(oView, oObjColl)
to retrieve dimensions in a drawing. The problem is it's taking a long time to run this part of code (and i run it several times).
The code is being used in an assembly and it has lots of occurrences made from multi-solid body components. I believe it's these that are causing the delay.
Is there a way to get round this?
thanks,
John
johnster100
i've created an example which shows it crashing when trying to retrieve all the dims from an oCC.
If I try and get a dim from a sketch it's still very slow.
thanks again,
John
johnster100
any help available on this?
laszlo_nagy
If I understand correctly, you want the dimmension only for "Solid1:1" CompOccurrence ?
(my code below)
In your Code, in the last row, you use wrong arguments for .GeneralDimensions.Retrieve  this is why Inventor Frozen
After arranging the dimmensions I got this result:
My Code in VBA:
Sub Test()
Dim oSheet As Sheet
Set oSheet = ThisApplication.ActiveDocument.ActiveSheet
Dim oView As DrawingView
Set oView = oSheet.DrawingViews.Item(1)
Dim oAssy As Inventor.AssemblyComponentDefinition
Set oAssy = oView.ReferencedDocumentDescriptor.ReferencedDocument.ComponentDefinition
Dim compOcc As Inventor.ComponentOccurrence
For Each oCC In oAssy.Occurrences.AllLeafOccurrences()
    If oCC.Name = "Solid1:1" Then
        Set compOcc = oCC
        Exit For
    End If
Next
Dim oObjColl As Inventor.ObjectCollection
Set oObjColl = ThisApplication.TransientObjects.CreateObjectCollection
'Add All Retrievable Dim
Dim oObjCollAllDim As Inventor.ObjectCollection
Set oObjCollAllDim = oSheet.DrawingDimensions.GeneralDimensions.GetRetrievableDimensions(oView)
'Select Dim which are Connected To "Solid:1"
For Each obj In oObjCollAllDim
    If obj.ContainingOccurrence Is compOcc Then
         Call oObjColl.Add(obj)
    End If
Next
Call oSheet.DrawingDimensions.GeneralDimensions.Retrieve(oView, oObjColl)
End Sub
johnster100
thanks a lot for the reply.
When I try this code on my actual model(it's a lot more complex)  it's very slow (several minutes) at the line:
I also tried putting the Component Occurrence for the part in as the optional input but this was still slow.
thanks again,
John
