Rescale View with iLogic
alysonrssl
alysonrssl
Hi everyone,
Thanks to @JelteDeJong I know how to managed the rescale views in my drawings,
But I would like to only have ISO scale like :
1/200
1/100
1/50
Until 200/1
Do you know a way to "round" the value from this code or maybe set another parameter instead of giving dimension in (view, 10, 10) to have ISO scale ?
Thanks in advance,
Public Sub Main()
Dim frontView As DrawingView = sheet.DrawingViews.Cast(Of DrawingView).Where(Function(v) v.Name = "FRONT VIEW").FirstOrDefault()
	If (frontView Is Nothing) Then
		MsgBox("Front view not found")
	ReScaleView(frontView, 10, 10)
End sub
Public Sub ReScaleView(view As DrawingView, X As Double, Y As Double)
	If (view.ScaleFromBase) Then Return
	Dim XOrg As Double = view.Width / view.Scale
	Dim YOrg As Double = view.Height / view.Scale
	Dim XScale As Double = X / XOrg
	Dim YScale As Double = Y / YOrg
	view.Scale = Math.Min(XScale, YScale)
JelteDeJong
You might want to have a look at this function. You also might want to add all scales that you like to have. But don't change the order of the list.
	Dim minScale = Math.Min(XScale, YScale)
	Dim isoScales As New List(Of Double)
	isoScales.Add(1 / 50)
	isoScales.Add(1 / 20)
	isoScales.Add(1 / 10)
	isoScales.Add(1 / 5)
	isoScales.Add(1 / 2)
	isoScales.Add(1 / 1)
	isoScales.Add(2 / 1)
	isoScales.Add(5 / 1)
	isoScales.Add(10 / 1)
	isoScales.Add(20 / 1)
	isoScales.Add(50 / 1)
	Dim scaleCloseEnough = isoScales.First()
	For Each isoScale As Double In isoScales
		If (minScale > isoScale) Then
	Next
	view.Scale = scaleCloseEnough
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
alysonrssl
Thank you Jelte, that works perfectly!
