Replicating Catia tree / Inventor browser names from Catia STEP
christopher.mccabeX6AVJ
Hello All.
I am trying to replicate a CATIA assy model tree in Inventor via its STEP from CATIA. Everything in the conversion looks correct in Inventor:
These "browser names" do correspond correctly to the CATIA tree. My issue is if I go to "save as", Inventor saves them as generic nomenclature:
Pack & Go gives the same result.
_________________________________________________
My question is, are there options other than manually inputting these "browser names" from CATIA to the iProperties fields?
There are also sub assy's that are affected as well. I know Inventor has scripting ability, though this is not my strong suit.
Thank you in advance,
Christopher
florian_wenzel
it is not impossible, but a little bit complex.
There are many solutions.
I see, that in Catia you have probably repeatable parts.
In Inventor you have this parts, as separate Parts, correct me if im wrong.
Correct in Inventor should be =
EE0525001:1
EE0525001:2
EE0525001:3
EE0525001:4
etc..
Souch a Interface between 2 Diffrent CAD Software is not a easy job
Hello Florian,
Yes, you are correct. The reason I am posting this inquiry is because as I move through this task manually, I feel like it could be scripted.
My manual solution to your question is to "save and replace" one instance with the correct filename, then "component -> replace all" to swap out all other instances. I wonder if a script could I.D. one of each of the instances, save them with the correct filename, then the user must manually replace all through the tree.
Christopher
