Replacing titleblocks, Code will only replace 1st and last page
Message 1 of 9
I have put together some code from some pieces online. It is working well with one exception. It will only replace the 1st and last page titleblocks.
A little background. With our drawings we have a titleblock for page 1 and then we have a titleblock for page 2 and on. The code is replacing the 1st page with the correct (1st) page titleblock and the the last page with the correct (page2) titleblock. The titleblocks in the middle however are getting page 1 titleblocks. Any suggestions would be greatly appreciated. I am very new with iLogic so be gentile:-)
    Dim oDrawingDoc As Inventor.DrawingDocument
    Dim oSheetNumber As Integer
    Dim oActiveSheetNumber As Integer
    Dim oActiveSheetName As String
    Dim oSheet As Sheet
    Dim oSourceTitleBlockDef As TitleBlockDefinition
    Dim oNewTitleBlockDef As TitleBlockDefinition
    oDrawingDoc = ThisApplication.ActiveDocument
    oActiveSheetName = ActiveSheet.Name
    oSheet = oDrawingDoc.ActiveSheet
    If (oSheet.TitleBlock.Name = "page1titleblock") Then
        oTitleBlockName = "page1titleblock"
    ElseIf (oSheet.TitleBlock.Name = "page2titleblock") Then
        oTitleBlockName = "page2titleblock"
     Else:
    End If
For oSheetNumber = 1 To oDrawingDoc.Sheets.Count
        oDrawingDoc.Sheets(oSheetNumber).Activate
        If Not oDrawingDoc.ActiveSheet.TitleBlock Is Nothing Then
            oDrawingDoc.ActiveSheet.TitleBlock.Delete
        End If
    Next oSheetNumber
    Dim oTitle As TitleBlockDefinition
    Dim oTitleBlock As TitleBlock
    For Each oTitle In oDrawingDoc.TitleBlockDefinitions
        If oTitle.IsReferenced = False Then
        oTitle.Delete
        End If
        Next
ThisDrawing.ResourceFileName = "path\to\Template\template.DWG"
ThisDrawing.KeepExtraResources = True
ActiveSheet.TitleBlock = "page1titleblock"
ActiveSheet.TitleBlock = "page2titleblock"
    oSheetNumber = 1
        ActiveSheet.TitleBlock = oTitleBlockName
    oSheetNumber = 2
Replies (8)
Message 2 of 9
NachoShaw
Hi
i havent read your code but you will need to itterate through the sheets and replace the titleblock independently. i have made a tool that does this and im in the process of making it into an addin. I will post a video very shortly for you see if it what you are trying to achieve
Nigel
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Message 3 of 9
NachoShaw
Hi
See video attached
Nacho
Message 4 of 9
GosponZ
Here is code i'm using to change TB in multi sheets .Make parameter for Border. Insert empty sheet with new TB and run rule . Delete empty sheet
I'm sure there is better way but this one working just fine.
For Each sheetX As Sheet In ThisDrawing.Document.Sheets
ThisDrawing.Sheet(sheetX.Name).TitleBlock = "Your TB"
iLogicVb.UpdateWhenDone = True
ThisApplication.ActiveView.Fit
Next
If Parameter("Border") = "Border" Then
ActiveSheet.Border = "Border"
End If
Message 5 of 9
Thanks to all for your help and suggestions. The code is working:-)
Message 6 of 9
adam.nagy
Autodesk Support
Autodesk Support
Hi Molly,
Could you please mark the answer that helped as solution? 🙂
I think it's possible to mark multiple comments like that if you wish.
Cheers,
Adam Nagy
Autodesk Platform Services
Message 7 of 9
GosponZ
I can't see that option
Message 8 of 9
adam.nagy
Autodesk Support
Autodesk Support
Tha author of a thread can click "ACCEPT AS SOLUTION" on any comment made.
I also think this can be done on multiple comments of the same thread (if someone wants to) - I'm pretty sure I've seen a thread where multiple comments were greened out. 🙂
Cheers,
Adam Nagy
Message 9 of 9
GosponZ
Hi Adam,
maybe Molly can. I do not see ,not in option drop menu, or button for accepting solution.
