GOAL: replace the SketchImage.Image inside a sketch using the path to the new file (PNG, BMP, GIF, JPG).
IDEALLY: I'd like to update the 'embedded' ReferencedOLEFileDescriptor but I do not see how to match that to the SketchImage. I also do not see a way to update the ReferencedOLEFileDescriptor. Am I wrong?
I would also accept being able to update the SketchImage.Image (as IPictureDisp) but that is read-only.
LESS IDEALLY: I am currently trying to place a new sketch image >> move it into the same position, rotation, and size >> correct the Decal Feature definition > correct the assembly joint (that uses the sketchimage) 2 levels up.
CLARIFY 5/31/2022: I see now it was not clear above that my scenario is an 'embedded' Image so I cannot update or overwrite a file.
