Replace References on mulit sheet drawing with ILogic
j.brodersen
j.brodersen
Hi all,
I spent hours to find a solution for my "problem" but unfortunately without any luck.
I found the rule below in another post and customised it so far, the only thing I can't get working is the Replace References part in the "privat sub".
We are working with mulit sheet drawings and I want the rule to go through each sheet and replace the referenced models which has been created in the first part of the rule but I can only get the rule to change/replace the reference on the first sheet.
I tried already to change the referenceddocuemntdiscriptions.item(1), added a "for each ... in .." but only with the result in getting the ERROR message.
Can some one either point out to me what I need to change to get the rule working or change it for me?
Sub Main()
 Dim Path As String = ThisDoc.Path & "\"
  Dim tPath As String = ThisDoc.WorkspacePath + "\Test Ordner\Bauteile & -gruppen\"
 Dim FileChange As Boolean = False
 InvDoc = ThisDoc.Document
 Dim refDocs As DocumentsEnumerator = InvDoc.AllReferencedDocuments
 Dim refDoc As Document
 'MessageBox.show(refDoc.DisplayName)
Dim ext As String
 'input box to enter new file name
ext = InputBox("What is the ending for the files?", "New File Name", "-")
 'NewFileName = InputBox("What is the new file name for " & refDoc.DisplayName & "?", "New File Name", iProperties.Value(refDoc.DisplayName, "Project", "Part Number"))
   If ext = 0 Then
   Exit Sub
   End If
     'if the new file name is blank then use the same name
     If ext = "" Then
         MessageBox.Show("Fehler darf nicht leer sein, bitte eine engabe machen", "Fehler")
     End If
 For Each refDoc in refDocs
     If refDoc.DisplayName.EndsWith(".ipt") = True Then
         refDoc.DisplayName = refDoc.DisplayName.substring(0,refDoc.DisplayName.length-4)
         'MessageBox.show(NewFileName)
     End If
NewFileName = refDoc.DisplayName + ext
     If refDoc.DisplayName <> NewFileName & ".ipt" Then
         If System.IO.File.Exists(tPath & NewFileName & ".ipt") Then
             Component.Replace(refDoc.DisplayName, tPath & NewFileName & ".ipt", True)
         Else
             Dim oldName As String = refDoc.DisplayName + ".ipt"
             'if it does not exist then recreate the file
             refDoc.saveas(tPath & NewFileName & ".ipt",False)
             Call UpdateDrawing(Path, oldName, NewFileName)
         End If
         FileChange = True
     End If
 Next
 If FileChange = True Then
     NewAssemblyName = refDoc.DisplayName + ext
     If NewAssemblyName <> "" Then
         Dim oldName As String = ThisDoc.FileName(True) 'include extension
         ThisDoc.Document.SaveAs(tPath & NewAssemblyName & ".iam" , False)
         Call UpdateDrawing(Path, oldName, NewAssemblyName)
     End If
 End If
 iLogicVb.UpdateWhenDone = True
 End Sub
 Private Sub UpdateDrawing (ByVal Path As String, ByVal oldName As String, ByVal newName As String)
	Dim zPath As String = ThisDoc.WorkspacePath + "\Test Ordner\zeichnungen\"
     Dim oDestinationDoc As DrawingDocument
     Dim strFileExtension As String
	If oldName.EndsWith(".ipt") Or oldName.EndsWith("iam") Then
	strFileExtension =  oldName.substring(oldName.Length-4,4)
	End If
     oldName = oldName.substring(0,oldName.Length-4)
	 End If
     Dim sFileName As String = Path & oldName & ".idw"
     Try
         If System.IO.File.Exists(sFileName) Then
             oDestinationDoc = ThisApplication.Documents.Open(sFileName)
             oDestinationDoc.saveas(zPath & newName & ".idw",False)
             Dim oDocDescriptor As DocumentDescriptor
             oDocDescriptor = oDestinationDoc.ReferencedDocumentDescriptors.Item(1)
             Dim oFileDescriptor As FileDescriptor
             oFileDescriptor = oDocDescriptor.ReferencedFileDescriptor
             oFileDescriptor.ReplaceReference(tPath & newName & strFileExtension)
             oDestinationDoc.Update()
             oDestinationDoc.Close
         End If
     Catch
         MessageBox.Show("error")
     End Try
 End Sub
chandra.shekar.g
Autodesk Support
Autodesk Support
@j.brodersen,
Please provide non confidential files to investigate.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
j.brodersen
Hi
I've tried now to uploade the files from my pc at work and at home but it wound let me!?
Is there another way how I can provide the files?
chandra.shekar.g
Autodesk Support
Autodesk Support
@j.brodersen,
Sorry for late reply,
Hoping that below iLogic code may be helpful.
Sub Main()
    Call ReplaceFileReference(ThisDoc.Document, "C:\PartA.ipt", "C:\PartB.ipt")
End Sub
Sub ReplaceFileReference(oDoc as Document, oRefToRemove As String, oRefToInclude As String)
    For Each oFD In oDoc.File.ReferencedFileDescriptors
        If oFD.FullFileName = oRefToRemove
             oFD.ReplaceReference(oRefToInclude)
        End if
    Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
j.brodersen
Hi
no problem and thank you for your reply.
I tried to implement your code in my rule but unfortunately with out the result I was hoping for.
I've tried a few things to day and came up with the code below which worked the first time I ran the rule, it just showed the error msgbox in the end. But now on the second and third try it just changed again the first sheet and ignored the other two, do you have any idea why?
Sub Main
End sub
	End If
	 End If
     Try
			 For Each Sheet In oDestinationDoc.Sheets
			 MessageBox.Show(Sheet.Name)
			 Sheet.activate
			 oViews = oDestinationDoc.ActiveSheet.DrawingViews
			 Dim oView As DrawingView
			 For Each oView In oViews
	 Next
			 Next
         End If
     Catch
     End Try
 End Sub
Thanks for your help so far and regards
Johann
chandra.shekar.g
Autodesk Support
Autodesk Support
@j.brodersen,
Try below iLogic code.
Sub Main()
    Dim oDoc As DrawingDocument
    oDoc = ThisApplication.ActiveDocument
    Dim oDescriptor As DocumentDescriptor
    For Each oDescriptor In oDoc.ReferencedDocumentDescriptors
        If oDescriptor.ReferencedDocument.DisplayNameOverridden = False Then
            Call oDescriptor.ReferencedFileDescriptor.ReplaceReference("C:\Temp\Newpath\" & oDescriptor.ReferencedDocument.DisplayName)
        Else
            Call oDescriptor.ReferencedFileDescriptor.ReplaceReference("C:\Temp\Newpath\" & oDescriptor.ReferencedFileDescriptor.RelativeFileName)
        End If
    Next
    Call oDoc.SaveAs("C:\Temp\NewPath\" & oDoc.DisplayName, True)
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
